aero145
Now It's Soft
Fri Dec 01, 2006 12:56 am
Hello!
I just got these two photos rejected for soft. I think I agree with the first one, but I do not with the latter one... What do you think?
http://www.airliners.net/procphotos/...=20061130_TF-FTN-0043-26112006.jpg
http://www.airliners.net/procphotos/...=20061130_TF-BOR-0039-26112006.jpg
OK, I sharpened the BOR photo a little... any better?
Big version: Width: 1200 Height: 800 File size: 594kb
Thanks in advance,
David
linco22
RE: Now It's Soft
Fri Dec 01, 2006 1:01 am
David,
First one is a touch soft, but I think the second I worse. Might even be slightly OOF??? On the second edit I still think the tail is very soft.
Colin
jajo
RE: Now It's Soft
Fri Dec 01, 2006 1:05 am
Nice David!
The sharpened one is better. TF-BOR is not a common reg in the DB so I think has a chance!
/ jajo
[Edited 2006-11-30 17:07:04]
aero145
RE: Now It's Soft
Fri Dec 01, 2006 1:09 am
Quoting Linco22 (Reply 1):
First is blurry here, so I've quit it.
Second is 100% not OOF, but CAN be blurry, or, this is the effect of a lots of crop.
Jajo, thanks...
timdegroot
RE: Now It's Soft
Fri Dec 01, 2006 1:30 am
second is blurry (tail), I'd forget about it
Tim
Alderman Exit
aero145
RE: Now It's Soft
Fri Dec 01, 2006 1:40 am
Oh well!
Going to try this again if I can get a 1.4x... cropped a lot from 200mm.
jumbojim747
RE: Now It's Soft
Fri Dec 01, 2006 5:46 am
Quoting Aero145 (Reply 5):
David i think when your panning your focus point is moving as the aircraft is moving along but not focusing on the entire image .
You might know this already but try this next time your out.
1- All points focus not only on center point.
2- Use the servo mode on the camera that will help you achieve continuous focus as your panning.
Cool shots by the way.
On a wing and a prayer
aero145
RE: Now It's Soft
Fri Dec 01, 2006 7:46 am
Quoting JumboJim747 (Reply 6):
That's right.
Ah! Always using the centre one...
 Wow! I hate the servo mode... I'll think about it.
Thanks. That's just Iceland...  Silly
