cactushp
Help For Night Photo
Sun Dec 03, 2006 2:54 pm
Hello, I shot this at KFFZ (Falcon Field, Mesa, AZ) this evening and I was wondering if anyone could offer me any suggestions on improving this photo. I am thinking that the white balance should have been adjusted.
Big version: Width: 1100 Height: 733 File size: 128kb
Shot at KFFZ
Sorry, I was on the landline
Q330
RE: Help For Night Photo
Sun Dec 03, 2006 4:45 pm
There's a lot of jpeg compression all over the photo. You should be sure to save at the best quality setting available. It's also oversharpened in places.
-Q
Long live the A330!
unattendedbag
Sun Dec 03, 2006 4:48 pm
Those thin cheat lines are getting you in trouble. The color is a bit off, but those cheat lines are mixing together and are going to be tough to seperate.
Slower traffic, keep right
timdegroot
Sun Dec 03, 2006 8:28 pm
Oversharpening and compression. Also needs ccw, and color temperature could be cooler.
Tim
Alderman Exit
rufruf
Sun Dec 03, 2006 9:54 pm
It's a fine photo. Depth of field is good. The whites are good. I think it's fine.
Background colours are true.
cactushp
Mon Dec 04, 2006 1:46 am
Thanks for all the replys. I adjusted the color tempature and I neat imaged it.
Original:
Shot at KFFZ
New:
Big version: Width: 1100 Height: 733 File size: 115kb
aero145
Mon Dec 04, 2006 1:56 am
Still needs a CCW rotation, and I'd like to get the yellow cast off to be normal white aircraft.
ThierryD
Crew
Mon Dec 04, 2006 2:05 am
Quoting CactusHP (Reply 5):
New:
Too soft; jaggies on the bottom side of the nose.
Thierry
"Go ahead...make my day"
raptors
Mon Dec 04, 2006 2:25 am
I still see lots of jpeg compression which leads me to a question of why this seems to be more pronounced on nights shots. How does one reduced this compression, it doesn't seem as much of a problem during the day?
Back to the photo, nice, but I think you will struggle to get it up to A.net standards, perhaps just one for your personal collection.
Good luck,
Stuart
SSC/111/146/AR8/AT7/AN3/AB4/6/310/319/20/21/332/3/343/6/703/722/732-9/74L/2/4/F/752/3/772/3/W/E170/190/CR7/9
TZ
Mon Dec 04, 2006 8:56 am
I think it has the ingredients to be accepted, and being a fan of night shots, I am happy to have a go at an edit if you want to email me the original? Email me through my profile if you'd like me to try.
TZ
TZ Aviation - Aeropuerto de los Banditos Team Images
September11
Mon Dec 04, 2006 10:47 am
Quoting TZ (Reply 9):
Amen -- I'm a fan of night shots, too
Not a bad night shot, though
Airliners.net of the Future
Vio
Wed Dec 06, 2006 8:05 am
... on a side note...
Today I purchased my first camera (worth mentioning). A Nikon D50 with a Nikkor AF 70-300mm f4.4-5.6D ED. My goal is to snap quality photos good enough for airlines.net.
I know that some photos need modification etc. such as the photo above. What programs do you use for that? I would like to buy it and start learning it. I work for a software company (part time), but I'm more into mechanical design than graphic design, etc...
Vio
eadster
Wed Dec 06, 2006 8:58 am
Quoting Vio (Reply 11):
Main ones used here are Photoshop or Photoshop elements. Plenty of help to be found in these forums if you ask the questions.
Between the two shots, the softer one has a red cast to me and now the edited version has a yellow cast. The jaggies on the cheat lines are going to be really hard to make look right, as they are so close together.
Quoting Rufruf (Reply 4):
Yeah I agree. With night shots, too much changing around of colours etc causes it to me not as natural as it was when it was taken and to me, leads to more of a manipulation concern more than anything.
cactushp
Tue Dec 12, 2006 8:36 am
Thanks for the edit by TzAviation! I think he did a fine job editing the photo. I would also like to thank the screeners for accepting the photo.
Photo © Scott Mulhollan
[Edited 2006-12-12 00:39:55]
NicolasRubio
Tue Dec 12, 2006 9:49 am
Great one! It is already in my "My favorite night shots!" album!
Nicolas Rubio
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
JohnJ
Tue Dec 12, 2006 10:57 am
Quoting Cactushp (Reply 13):
Very nice shot. I would be interested to know the steps TZAviation went through to produce the final edit.
