Ander
"Double" Rejection
Mon Dec 04, 2006 7:47 am
Hi all,
I've recently had this "double" rejection:
http://www.airliners.net/addphotos/r...big/20061202_t340axalp2b101006.jpg
My other photo of the same helicopter is this one:
Photo © Ander Aguirre - AirTeamImages
of the same day. Me thinks it is a different view of the same aircraft, appart from the fact that this time it is shooting a flare.
What are your views.
Ander
Yes, I know I should have cheated and put a different day, but...  Wink
Born to tri.
timdegroot
RE: "Double" Rejection
Mon Dec 04, 2006 7:55 am
Too similar, rightly rejected. Good to see your honest about it Wink
Tim
Alderman Exit
walter2222
Mon Dec 04, 2006 8:23 am
Hi Ander,
That's a pity! Personally, I prefer the one shooting the flare!
Quoting TimdeGroot (Reply 1):
They are indeed flying and have almost identical attitude.
I have a similar question: I have this one in the queue:
http://www.airliners.net/addphotos/b...061011_CRW_6990_RT8_WVB_1200px.jpg
... and I have already a shot (from a different angle of about 45 degrees) accepted, but they are both static shots (the aircraft is preserved, so it does not fly anymore...  Sad ) and it was shot on the same day (rare opportunity to get into the base). Would this be allowed or would it also be called NOA_Double?
Thanks for any clarification,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
ptrjong
Mon Dec 04, 2006 8:32 am
Quoting Walter2222 (Reply 2):
Hi Walter,
Photo © Peter de Jong
These two were accepted. I guess it might be borderline though.
Peter Smile
Kereru
Mon Dec 04, 2006 9:12 am
Quoting Ptrjong (Reply 3):
Hmm one accepted into the DB May 2005 and the other October 2006. Only 5 total in DB and yes you were lucky Peter, rarity saved the day.
Colin
Good things take Time.
walter2222
Mon Dec 04, 2006 9:14 am
That's why I was asking the question...
PS: Nice shots, Peter!
Walter
ptrjong
Mon Dec 04, 2006 9:37 am
Quoting Kereru (Reply 4):
Hi Colin,
It's probably smarter not to upload these together, but on the other hand the upload date shouldn't really matter , right?
eadster
Mon Dec 04, 2006 10:36 am
Should have uploaded the one with the flare first! Much more interesting shot I think!
chris78cpr
Mon Dec 04, 2006 5:36 pm
Unlucky Ander, i can see where they are coming from though.
LOVE the shot tho, i think catching the flare really adds something to the image.
I keep seeing your shots and am amazed at the quality of them, keep them coming!
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
Chukcha
Mon Dec 04, 2006 10:58 pm
The one with the flare seems a lot more interesting shot. Maybe you could ask the screeners to remove the other one and replace it with the one with the flare?
BTW, I have a shot in the database of a taxiing aircraft. Would a photo of the same airplane on the same day taking off count as a double?
[Edited 2006-12-04 15:00:49]
Lanas
Mon Dec 04, 2006 11:10 pm
Quoting Chukcha (Reply 9):
I believe it doesn´t, because the 'double' rejection applies for two shots on a same sequence, or a two very similar situations on a same day. I think that your case won´t qualify for a double rejection. What you can do is post the photos in question so we can see them and discuss about them.  yes
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Chukcha
Tue Dec 05, 2006 8:21 am
Quoting Lanas (Reply 10):
Sure, why not. Here is the database photo:
Photo © Andrei Bezmylov
And here is the one in question:
Big: http://www1.airliners.net/uf/536910456/1165272405ekvnIj.jpg
Lanas
Tue Dec 05, 2006 9:15 am
Then I guess it won´t be rejected for double. See that you show the other side of the a/c, and also the action is different (Takeoff vs. taxiing).
One comment appart, on the second shot the guy is not flying! It must have been an instant that the guy left the controls! Very interesting pic.  Wink
Good luck with it.
Cheers!
Lanas.-
Chukcha
Tue Dec 05, 2006 9:35 am
Thanks for comments, Lanas. I think, I'll give it a go.
Andrei
