ac888yow
Questions About My 100-400 L Is
Fri Dec 15, 2006 12:25 am
Hello:
I was recently out shooting at a different area of my home airport, one that required shooting through a fence.
Basically, I was pressing the lens (hood) up against an opening in the fence and shooting away, with the IS on. My questions are:
1) I know that, for example, when using a tripod the IS must be turned off otherwise I risk damage to the lens. Is pressing the camera up against the fence similar to using a tripod in the sense that I risk damage to the lens? Should I turn the IS off when shooting through a fence?
2) While shooting through the fence, I noticed that pretty much all of my shots, taken at the long end of the zoom, exhibit sort of an out of focus or blurry characteristic. I wonder, could this have been caused by #1 above? Perhaps leaning the lens up against the fence threw the IS "out of whack" resulting in these poor images?
Thanks for any help,
- Peter -
INNflight
RE: Questions About My 100-400 L Is
Fri Dec 15, 2006 12:28 am
I don't have knowledge on whether the IS causes your blurriness (sounds unlikely though), but I have shot through fences with the 100-400 on a tripod ( IS on ) and still got decent results, so go figure  Smile
Florian
Jet Visuals
IL76
Fri Dec 15, 2006 12:43 am
I always remove the lenshood to get as close to the mesh as possible... No problems there (with IS on). At 400mm the mesh is basically invisible, at 100mm a very small mesh could give dark corners.
E
Kukkudrill
Fri Dec 15, 2006 1:08 am
Quoting AC888YOW (Thread starter):
I was under the impression that you have to turn the IS off not because it might damage the lens but because vibrations from the IS mechanism itself could set up a feedback loop, causing the picture to move erratically. I doubt whether the same thing could happen when the camera is handheld, even though you might be partially resting it on a fence.
Charles
Make the most of the available light ... a lesson of photography that applies to life
ua935
Fri Dec 15, 2006 2:09 am
The out of focus or blurry charateristic is the fence. If you do not shoot exactly through the middlle the fence will be in the shot. Because you are shooting throuhg the fence they will only be very feint but they are there.
Live every second like you mean it
ac888yow
Fri Dec 15, 2006 2:30 am
Thanks for the responses.
So from what I'm reading leaning the lens up against the fence shouldn't cause erratic behaviour with the IS, and the poor image quality is probably unrelated.
I normally get pin sharp images with the lens all the way through to 400mm, so obviously this was a user problem (I was shaky, etc.) and/or the fence was in the way.
I should probably just get a ladder and get on with it ...
aero145
Fri Dec 15, 2006 2:57 am
Quoting AC888YOW (Reply 5):
I did that and never looked back, ladder is a must of an av-photog IMO, it can come in handy more often than looking over fence, also just for standing higher up... at least that's how it is here.
d
cosec59
Fri Dec 15, 2006 3:20 am
Quoting Aero145 (Reply 6):
Try that at LHR  Wink
Rules are for the obedience of fools but for the guidance of wise men
jorge1812
Fri Dec 15, 2006 4:17 am
Sure a must but keep in mind that it's not always handy when transporting without a car.
Georg
aero145
Fri Dec 15, 2006 5:27 am
Quoting Jorge1812 (Reply 8):
Well, for spotting I sometimes cycle more than one kilometer and I hold the ladder in my right hand. So, maybe it's not at all that bad if you're not driving......
Quoting Cosec59 (Reply 7):
Try that at LHR
 rotfl
lasham
Crew
Fri Dec 15, 2006 6:13 am
Try that at LHR
Can be done. Just got to use it for a short time when the coast is clear!
Tony
No sun no fun
