gerardo
Question About Leveling A Photo
Wed Dec 20, 2006 5:18 am
This is getting frustrating, or my eyes are teasing me.
Dec 1 I had the chance to get a night shot of the Helvetic F100 with the new colors. I uploaded as hot photo, but had it rejected for motive after 5 days (remember: hot photo - 5 days). Possibly because of a lamp, who knows, who cares.
Anyway, I uploaded another version as hot photo again (at this time, there was just one photo of that livery in the db), this time rejected for unlevel (again after 5-6 days), much to my surprise, so appealed and got it rejected again (of course! I mean, one accepted appeal this millenium should tell me a story...):
http://homepage.sunrise.ch/mysunrise...ery/f100_2l_hb-jvc_061201_3959.jpg
OK, perhaps I'm getting old, so I rotated the photo, uploaded again as hot photo, but forgot to state why it was a hot photo. I mean, I thought, they would finally know it after 2 fruitless attempts. Of course, rejected after a few hours "priority why?". I asked, if I had to upload again. Reply:
"There is a message in your rejection:
"f100_2l_hb-jvc_061201_fan.jpg priority why?"
If you mark priority, and the aircraft isn’t considered to be priority, it will be rejected.
Please upload again without the “priority” box ticked."
Of course, uploaded again and of course rejected again for unlevel (remember, I rotated as told by the screener and headscreener). Note to self: one accepted appeal in this millenium should really tell you a story! http://www.airliners.net/addphotos/r...1212_f100_2l_hb-jvc_061201_fan.jpg
Funny thing: It was also rejected for not having changed it. Of course, an appealed shot is not in the rejected queue anymore. So, the screeners compared the shot with the one I was told to upload again without the “priority” box ticked (see above).
That's the best way to p*ss off photogs, but anyway: how much do I have to rotate the photo to make it level?
Gerardo
dominguez(dash)online(dot)ch ... Pushing the limits of my equipment
waketurbulence
RE: Question About Leveling A Photo
Wed Dec 20, 2006 5:39 am
It needs CW rotation for sure. I used the measure tool but it still looked like it needed more than .6 CW rotation. I ended up at about .9-1.0 degrees CW rotation and that looked ok to my eyes.
-Matt
fergulmcc
Wed Dec 20, 2006 5:49 am
Not an easy one to level as there are no real points to use, but rotating it till it looked/felt right I would use about a 1deg CW rotation, based on the first one/link that you have posted.
Hope that helps
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
ptrjong
Wed Dec 20, 2006 6:09 am
As to priority, if it took five days priority was probably not granted, maybe because the other photo was meanwhile in the db?
When you uploaded for the second time, the other photo was in the db, and so there was no ground to ask for priority. Let alone the third time.
Peter
gerardo
Wed Dec 20, 2006 6:14 am
Thanks guys
Matt, just to make it sure: which photo are you referring to? Not that I rotate in the wrong direction again
Fegul, I rotated also 1° to check. In my opinion, the photo looks unlevel, but perhaps because I know, there is a bit of distortion due to the wide angle. I guess, you levelled it acording to that building on the right, correct?
Anyway, here is a version, rotated a bit less than 1° compared to the 1st one.
http://www.airliners.net/addphotos/b...100_2l_hb-jvc_061201_3959_fan4.jpg
Any better?
Gerardo
[Edited 2006-12-19 22:22:55]
waketurbulence
Wed Dec 20, 2006 6:22 am
Sorry about not being specific. I used the 2nd photo you linked.
-Matt
gerardo
Wed Dec 20, 2006 6:24 am
Thanks Matt! Equals more or less Fergul's suggestion.
Gerardo
fergulmcc
Wed Dec 20, 2006 7:14 am
Quoting Gerardo (Reply 4):
Nope!!  Smile The building on the far right is too far to the side to be used as a reliable leveling datum. I leveled the aircraft till I felt that the whole photo looked right. Your photo has a feel that it's leaning to the left.
Hope that helps
Take care
Fergul  sun
gerardo
Wed Dec 20, 2006 7:18 am
Do you mean the one in the queue?
Cheerio
Gerardo
fergulmcc
Wed Dec 20, 2006 7:32 am
Any better?
The above link doesn't work but the earlier one looks a lot better, just be carefull of your exposure, some areas are borderline over-exposed.
take care
Fergul  sun
gerardo
Wed Dec 20, 2006 7:49 am
Sorry for the bad link, I meant this one:
As so far the highlights have not been cause for a rejection, I'll let it in the queue.
Thanks so far
Gerardo
Lanas
Wed Dec 20, 2006 12:05 pm
Gerardo
It´s better now but I think it has gone a little off CW, in my opinion. It´s like if the ramp was leaning to the right side.
I guess you should find a good feel by checking on the lightposts under the tail and the cars seen through the space below the fuselage. Get a good average level for both elements and you should be fine with it.
Quoting Ptrjong (Reply 3):
Correct. I believe priority screening is allowed for the first pic, since it´s a way of allowing hot news to reach the site faster.
Good luck with it.  Smile
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Rotate
Wed Dec 20, 2006 6:22 pm
Hi Gerry
I really can feel your pain re those countless rejections for only 1 picture. i think everything has been said on that topic.
Re the last picture I also think it now needs a tiny CCW rotation ...
Hope to see u around again at ZRH
Robin
ABC
edoca
Wed Dec 20, 2006 7:07 pm
Quoting Rotate (Reply 12):
Hi Gerardo
yes that's how it looks to me as well. A tiny bit of CCW... Interesting to see how difficult it gets in a shot like this... Good luck, I hope that a shot of this quality shot gets accepted at some point.
eadster
Wed Dec 20, 2006 7:41 pm
On a slight side note (not sure if mentioned above) I like the one linked from a different site, as alot of the yellow cast was removed.
gerardo
Thu Dec 21, 2006 2:17 am
fergulmcc
Thu Dec 21, 2006 5:38 am
Quoting Gerardo (Reply 15):
Would that look better then?
A lot better,  bigthumbsup  let us know how you get on!!
Take care
Fergul  sun
gerardo
Thu Dec 21, 2006 6:25 am
I'll put the first one and keep you updated. See you in a week or so  Wink
Gerardo
gerardo
Fri Dec 29, 2006 4:18 pm
It took a bit longer than a week to screen it but anyway:
Photo © Gerardo Dominguez
Thanks guys!
Gerardo
fergulmcc
Fri Dec 29, 2006 7:24 pm
Quoting Gerardo (Reply 18):
Thanks guys!
You are very welcome, glad to see in the DB,  bigthumbsup
Take care
Fergul  sun
Users browsing this forum: Google [Bot] and 1 guest
