TedTAce
Advice For An FNG...
Tue Dec 26, 2006 1:00 pm
So,
Santa gave me a Nikon D-80 for Christmas.
It has the 18-55 and the 55-200 lens kit(s) and I think will be a great starter camera.
Now I know ISO is how fast the 'film' absorbs light, I know that if you set the ISO too high you get grainy shots.
I know that the faster you expose a shot, the more light you have to have and the harder it is to get the subject and any backgound to focus.
Now today I was at KMIA, and I took a LOT of shots in automatic mode (JPG fine), the few exceptions being manually focusing some shots that had something in the foreground.
Most of it was very marginal, and I knew it would be given my inexperience. I got a lot of off center, a lot of off horizon shots (odd thing was I was getting rushed and for some reason I formed the habit of aligning the horizon with the angle of the a/c body) and the lighting was usually wrong.
I did get this shot that I like looking at on my laptop(lcd), but not my desktop (CRT).
http://www.airspaceonline.com/Aircraft/DSC_0095.JPG
Now when you look at it in a browser (resized to fit the screen) it's OK, but when you look at it in full resolution it's horrible.
Besides shooting in NEF, RTFMing(on the to do list after the holidays), and probably taking a photography course; what other advice can you give?
This space intentionally left blank
Fly747
RE: Advice For An FNG...
Tue Dec 26, 2006 1:12 pm
One thing I noticed from the EXIF is you shot this @ ISO 1600. There's no need for such a setting on what appears to be a bright day. That gave you shutter speed of 1/4000th of a second which just freezes the props making them look as if they were shut off. A no no for props.
Read your manual a couple of times and go out there and shoot as much as you can.
Ivan
CalgaryBill
Tue Dec 26, 2006 2:05 pm
On a nice sunny day you should have no problem shooting at ISO 100. Nikons are not good at higher exposures (and before anyone poo-poo's me for slagging Nikon, I shoot Nikon!) so keep it low if you can.
If you want a deeper understanding of ISO, exposure, etc, read "The Negative" and "The Camera" by Ansel Adams. While "The Negative" seems out of date, it's almost entirely about how to expose an image and most of that information applies to negs, slides and yes, digital.
You're already doing the best possible thing you can though - getting out and using the camera.
B
JakTrax
Wed Dec 27, 2006 4:44 am
The shot above looks over-exposed and, indeed, there really was no need for the camera to select ISO 1600. Using any DSLR on full auto is asking for trouble - if you want automatic operation but still require some sort of control use the 'P' mode. When you've learned the basics in this mode, try Av (aperture priority), which is the mode most commonly used by aviation photographers.
If the camera persists to over-expose in P or Av mode you'll need to change the exposure compensation and reduce it by 1/3 of a stop (to start with) - do be careful, however, as different situations need different compensations!
As the others have said, gaining a better understanding of when and where to use the advanced functions involves fully reading the manual.
Karl
TedTAce
Sat Dec 30, 2006 7:36 am
So...first and foremost thank you all for the advice, I really appreciate your input.
Today I read some more of the manual and read Illustrated Guide To Rejection Reasons (by ThierryD Dec 25 2006 in Aviation Photography) . I took the camera out into the back yard (after figuring out how to control f, exposure time/and ISO in manual mode (I still don't know any other way to set ISO then through the menu I'd have thought there would be a wheel for it too)).
Due to the guide(above) I stayed @ ISO 100 using my 55-200 and took a lot of shots with various exposure lengths and f stops that looked good on the viewfinder(preview), but when I got the stick inside were nauseating. Either the light was right/ok and focus was blurred/sucked or it was underexposed and still not that sharp.
To say I have a long way to go appears to be a great undrstatment.
Now the questions I have for you all is what benefit am I going to gain by using A or S mode as opposed to sticking to my guns in manual? I mean are they not alternate names for automatic with a little bit of choice thrown in there? How much of a hard on should I have for shooting ISO 100? I remember in my old AE-1 days I shot lots of decent shots with 400 film.
Also should I give up on NEF for now as getting even a rudimentary shoot right seems to be a month or two away?
Also is there a way to keep the post shot preview mode running, but have it not react to the wheel controls?
clickhappy
Sat Dec 30, 2006 8:04 am
I would stick to jpegs until you get your technique down. I think it is pretty well accepted at this point that the D80 tends to overexpose, so keep that in mind. If you were in manual what app and shutter speed where you shooting at? Also, you don't mention the lighting conditions. Check out Flexible Program mode as a good place to start, get some auto input + the ability to tweak settings.
viv
Sat Dec 30, 2006 8:17 am
Quoting TedTAce (Thread starter):
The D80 is far more than that - it is essentially a D200 with a plastic body. It is capable of great shots.
  See your shot above - very grainy (also over-exposed).
Bad idea.
Many beginners do this.
Quoting TedTAce (Reply 4):
Aperture priority allows you to directly control the aperture, while the camera will set the corresponding correct shutter speed. A small aperture (high f number) will give you more depth of field than a large aperture.
Shutter priority allows you to directly control the shutter speed, while the camera will set the corresponding correct aperture. For flying aircraft, it is important to keep the shutter speed high enough to avoid blurred images. The traditional rule of thumb is that your shutter speed should not be slower than the focal length of the lens, e.g. when shooting at 400mm the shutter speed should be 1/400th/sec or faster. Of course, this does not hold true for lenses with image stabilisation ("VR" in Nikon-speak). With these lenses you can get away with a shutter speed two or even three stops slower.
Shoot at ISO 100 or 200 unless low light prevents you from doing so.
[Edited 2006-12-30 00:23:48]
[Edited 2006-12-30 00:31:08]
viv
Sat Dec 30, 2006 8:37 am
Nope. That is one of the reasons the D200 is more expensive.
Users browsing this forum: No registered users and 20 guests
