LIPH
Canon 5d Or 30d?
Thu Dec 28, 2006 9:24 pm
Which one of these 2 cameras would you suggest upgrading from a 300d ? Which are the pro and con of both ?
Thanks in advance for suggestions.
Life sucks. Then you die. Live fast, die young.
viv
RE: Canon 5d Or 30d?
Thu Dec 28, 2006 10:06 pm
Rotate
Thu Dec 28, 2006 10:10 pm
The thing which makes this 2 cams different to me is the crop factor. Take a look at your lenses , the places you go and the style you take photos ----> Then you can make your decision .....
Robin
ABC
OD720
Thu Dec 28, 2006 10:17 pm
The 1.6x crop factor of the 30D may help your reach with zooms.
Also, the 30D has a faster 5 f/s burst rate than the 3 f/s for the 5D.
LIPH
Thu Dec 28, 2006 10:30 pm
Actually cannot take a decision, really. It's also true that the 5d has a 12mpixel sensor while the 30d has a 8,2 megapixel sensor....
IL76
Thu Dec 28, 2006 10:35 pm
What lenses do you intend to screw on?
LIPH
Thu Dec 28, 2006 10:47 pm
Quoting IL76 (Reply 5):
Canon IS 100-400, Sigma 50-500, Canon 90-300 USM and 17-55....
aero145
Thu Dec 28, 2006 10:54 pm
Quoting LIPH (Reply 6):
and 17-55....
If it's the Canon EFs 17-55mm f/2.8 IS USM, you can only screw that on the 30D (and 300D, 350D, 400D, 20D and 20Da). The 5D doesn't accept EFs lenses.
IL76
Thu Dec 28, 2006 10:55 pm
Well, you've got your decision there: The 30D. The 18-55 does not fit the 5D and if it did, it would not do it justice (neither does the 90-300 and 50-500 do it justice).
E
[Edited 2006-12-28 14:55:56]
LIPH
Thu Dec 28, 2006 11:04 pm
Quoting IL76 (Reply 8):
Straight and clear...thanks ?  Smile
Garri767
Fri Dec 29, 2006 1:48 am
Neither! Both Suck! Get the D-80!!!!
signed,
the Nikon cheerleaders.
Back to reality, i would say the 30D.
Quoting OD720 (Reply 3):
Garri767
Two wrongs may not make a right, but three lefts do!
fergulmcc
Fri Dec 29, 2006 2:15 am
Be very carefull with Sigma DG lenses on the 5D or the 1Ds or any full frame sensors, i.e. sensors bigger than APS-C as they will cause vignetting, (light fall off on the corners) as they are designed for the smaller sensors. Buy a 30D and invest in some good glass.  Smile
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
flugnord
Fri Dec 29, 2006 5:38 am
IMO I would chose the 5D over the 30D any time...
The 5D just handles so good. Go out to a local canon shop and test out these two and see wits you like better...
Just use the EF-s lenses on your 300d an all the worlds problems are solved.
garry
Fri Dec 29, 2006 8:25 am
LIPH, I have both and if its mainly aviation photography you will use it for then get the 30 with an L lens (70-200f2.8 or the 300f4). Money invested in some top quality lenses is a good investment - compare the price of a top LISUSM lens today to say 2 years ago, and then compare the price of a 300D when first released to a 350 today.
If your photography extends beyond aviation and say action photography (perhaps landscape, portrait, weddings, macro) then get the 5D.
However, if you do buy the 5D make sure you can put some quality L glass on the front of it. The results will be superb but your bank balance will take a large hit!
Best wishes
Garry
www.garryridsdale.com
