sleekjet
How To Get A Good Rain Shot...
Wed Jan 03, 2007 5:49 am
I got an opportunity to shoot in a driving rainstorm last week. I knew going in that it would be hard to get quality shots. Here's one I took that shows such lack of quality:
http://img.photobucket.com/albums/v649/tim552/Storm_City1.jpg
So, how do you set up your camera to get passable results on rainy days? BTW, I have a Canon 300D.
II Cor. 4:17-18
bmibaby737
RE: How To Get A Good Rain Shot...
Wed Jan 03, 2007 6:02 am
You wont if theres that much rain falling down; most good shots here will be when the rain has stopped the suns popped out and theres still a huge flood of water on the runway...
acontador
Wed Jan 03, 2007 6:05 am
Hi Sleekjet,
I used a 350D+EF 70-200 f/4L USM combo, and set up the camera to normal exposure (for sunny days I need to use -2/3), ISO 100, WB to cloudy and F4.0 with Av. And at least I had to wait to have the aircraft as close as possible to get some decent results (so head-on shots rather difficult), as the rain+bad light basically have the effect that can be seen on your picture. After that, the rest is post-processing, with my mayor aim always to avoid too much grain visible.
Just sit back, relax and have a glass of Merlot...enjoy your life!
D L X
Wed Jan 03, 2007 6:06 am
I agree with BmiBaby. Rain will show up on film, and if there's a lot of rain between the camera and the subject, kiss the quality goodbye. Wait until just after the rain passes, or just before the rain arrives. I love shooting rainy-day shots, and I have a couple in the database if you'd like to see what I'm talking about.
mikephotos
Quoting Sleekjet (Thread starter):
Most of us usually set the camera to OFF  Wink
But seriously, since it's generally dark when it's raining you'll want to bump up the ISO of course. However, with lack of light, colors and overall quality will suffer a bit. It would have to be a very unique shot you're attempting to be worth a shoot in rain (sorta like what you attempted above). Action shots in dim light is always a tough capture.
Mike
codeshare
Wed Jan 03, 2007 6:15 am
..but pictures taken in extreme conditions are far more interesting than those on a normal sunny day.
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
mikephotos
Wed Jan 03, 2007 6:24 am
Quoting Codeshare (Reply 5):
That depends on who you're asking  Smile (Don't worry, I know they would probably be more popular on the hits-scale)
Mike
graphic
Generally you're gonna want to be zoomed away from the aircraft a bit, I've found that quality flaws are less noticeable when the subject is further away, so what you can do with the rain is back off a bit and maybe include some of the spray coming off behind the aircraft.
It'll look much more interesting too.
Demand Media fails at life
ThierryD
Crew
Wed Jan 03, 2007 6:25 am
 checkmark   checkmark   checkmark
Thierry
"Go ahead...make my day"
garry
Wed Jan 03, 2007 6:27 am
Convert it to black and white by using the channel mixer then play about with dodge and burn tool. You can acheive some nice results, not for this site but your own portfolio.
www.garryridsdale.com
fhlaran
Wed Jan 03, 2007 6:37 am
Hi Sleekjet
I have some shots in DB in rainy/storm day. I did not manage to do it again but I'm planning to do soon. I used a Canon EOS 300D when I did these shots. I used ISO 400 and increased 0,7 the EV. Also I did not try to shoot during these rainy days but when typical tropical TS falls. So you have a 10/15 minutes heavy rain and sun light in the vicinity, which help get more colors and use a lower ISO.
Here are 3 of these shots that I've sent to here (I don't know if with the today high standards these shots would have chance)
Photo © Fabio Laranjeira - Contato Radar
Fabio Laranjeira
sulman
Wed Jan 03, 2007 6:50 am
I find these really tough. Your picture would be great if it were a bit sharper (you've got some motion blur going on there) and it's slightly underexposed - the bright wing-root lighting on the a/c has thrown your camera's metering off about half a stop.
Next time, point your camera at the scene (without the aircraft) and make a note of the shutter speed and aperture - then switch to 'M' mode and dial these in. If the lighting doesn't change you can leave it like this until it does, then simply repeat - you should get a ballpark decent exposure this way.
Stick the 300D in ISO400 to keep the shutter speeds usable, you may even get away with ISO200, but the ultimate point is to get a nice, sharp image. Get ready to delete alot of junk though!
James
