Silver1SWA
Is This Centered Correctly?
Tue Jan 16, 2007 7:36 pm
I can't tell. It seems a bit off to me...like the aircraft is too high in the frame. However, lowering the aircraft increases a lot of "dead" space in the upper left hand corner. What do you think?
http://www.airliners.net/addphotos/big/ready/478roll27Jan1407.jpg
And while we're at it, anything else that can be changed/fixed? Thanks.
9V
RE: Is This Centered Correctly?
Tue Jan 16, 2007 8:22 pm
Quoting Silver1SWA (Thread starter):
No, it's too high in the frame.
jid
Tue Jan 16, 2007 8:26 pm
Centering looks fine to me ... Only other issue, there are slight jaggies on the port wing. Apart from that it looks good.
Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
airkas1
Crew
Tue Jan 16, 2007 9:31 pm
Quoting Jid (Reply 2):
Ditto.
Airliners.net Crew - Head Photo Screener
JeffM
Tue Jan 16, 2007 10:36 pm
Too high in the frame. I'd say the quality is iffy as well.
LIPH
Tue Jan 16, 2007 10:46 pm
Cannot really "feel" the plane there, due to the wierd angle...
Concerning the center I see it too low...
Good luck
Life sucks. Then you die. Live fast, die young.
ChrisH
Tue Jan 16, 2007 10:53 pm
feels balanced.
what seems to be the officer, problem?
Silver1SWA
Wed Jan 17, 2007 6:35 am
Quoting 9V (Reply 1):
Quoting AirKas1 (Reply 3):
Ditto.
Quoting JeffM (Reply 4):
Quoting ChrisH (Reply 6):
feels balanced
 scratchchin
Quoting LIPH (Reply 5):
Well, it seems to be a 50/50 split here. Must be a matter of opinion. I think I will leave it in the queue and see if I get a heads or tails from the screeners.
Thanks again.  bigthumbsup
locsta
Wed Jan 17, 2007 6:46 am
I just had a similar angle shot rejected for centered (among others) with a note saying "please center the entire A/C and not just the fuselage"
http://www.airliners.net/addphotos/r.../20070114_Boeing737-7ES-N367BJ.jpg
If you want to take that into consideration.
Kevin.
Missed 4 chasing 1
ChrisH
Wed Jan 17, 2007 7:00 am
yes that's a.nets preferred way of centering. It goes against traditional photography rules though.
Silver1SWA
Wed Jan 17, 2007 7:24 am
Quoting LOCsta (Reply 8):
That is the method I normally follow, but this angle is a bit trickier than others. The last time I tried to upload from a similar angle, it was of the JAL 744 that visited SAN last spring. I followed my usual method of ensuring the entire aircraft is centered but it got rejected because of centering. I figured it was because lowering it left too much space in the top corner.
I think I will leave it and see what happens. Heck, if Jeff is right, then the centering issue may be a moot point.  Wink
Users browsing this forum: No registered users and 4 guests
