JakTrax
Photoshop & Upload Help Please...
Thu Feb 01, 2007 5:30 am
Hi all,
I have just one photo currently in the database, which someone else (very kindly) edited and resized. This individual did a great job and my very first upload was accepted.
I got my own version of PS yesterday and have started playing with it. I've edited a shot into what I think is an acceptable upload, but since I really don't know what I'm doing when resizing, etc, I thought I'd ask. The original is 3.68mb, saved in max. quality (12 in PS as I remember) and 3461x2310 pixels. The revised image is 2000x668 pixels (same ratio kept), saved as quality 8 (high) and is 272kb. Is this OK? I know A.net uploads must be smaller than 1mb so can I keep upping the pixels until it's just under the limit or do I keep the size and save at a higher quality (say 11 or 12)?
Thanx for any help.
Karl
acontador
RE: Photoshop & Upload Help Please...
Thu Feb 01, 2007 5:37 am
Hi Karl,
Just use the search function in this forum, and you will find plenty of very good and detailed workflow examples for PS. Follow a couple and show us the result!
Just sit back, relax and have a glass of Merlot...enjoy your life!
codeshare
Thu Feb 01, 2007 5:39 am
You'll probably have compression at this ratio (8). Always try to save at maximum quality and minimum compression.
But the size is a bit strange, should be 3:2 ratio more or less. 1024 x, 1200 x or 1600 x are preferable sizes here.
So with the photo you mentioned, step down each time and save at max quality until the size reaches 1 MB.
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
dendrobatid
CalgaryBill
Thu Feb 01, 2007 5:59 am
I think you meant to say "the revised image is 1000x668?"
At that size you should have no trouble using quality 12 and still stay under 1 MB.
B
Psych
Thu Feb 01, 2007 7:57 am
Karl.
In my editing I always begin by cropping and resizing. As you are new to the editing process I would strongly recommend you resizing your edits to 1024 x 683 pixels. Then do the rest of your editing with this smaller file. At the end save that at maximum quality - 12. I cannot recall an occasion with a plane photo where doing this has resulted in a file larger than 1 MB. For 'standard' shots of an aircraft with no major background details you should be looking at something in the region 500 - 650 KBs.
Given the high quality standards here you really don't want to be saving your edits at anything less than maximum quality.
Cheers.
Paul
ThierryD
Crew
Thu Feb 01, 2007 9:06 pm
Quoting Psych (Reply 5):
Interesting statement; personally I do all my editing, except sharpening, BEFORE resizing. I believe you've much more freedom of movement that way.
After completion of my editing I only resize and sharpen and off it goes always saving at max quality if file size permits.
Thierry
"Go ahead...make my day"
Kukkudrill
Thu Feb 01, 2007 9:44 pm
Quoting ThierryD (Reply 6):
Likewise, except that the only cropping I do on the unresized photo (which I keep as a TIFF) is to get rid of slanting borders due to rotation.
The large TIFF enables me to produce hi-res jpegs on the fly if I need to. I don't crop this one tight to a.net standards because tight crops limit publishers' options when doing page layouts.
Make the most of the available light ... a lesson of photography that applies to life
JakTrax
Thu Feb 01, 2007 9:45 pm
Thanks guys. I get it now. Just one more question - at what aspect ratio should I save the file? I've narrowed ot down to two options:
a) based on the original photo
b) 6x4
The 6x4 option is surely keeping with the 3x2 ratio, no?
I'll edit a shot and quickly post it here, with a view to someone perhaps approving it.
Karl
ThierryD
Crew
Thu Feb 01, 2007 9:49 pm
Quoting JakTrax (Reply 8):
Check this out:
http://planecatcher.com/IGRR.htm#Size
Thierry
Btw: 6 x 4 = 3 x 2 in terms of ratios  Wink
JakTrax
Thu Feb 01, 2007 10:11 pm
OK, here's one I fiddled with briefly. Have I gone over-board with anything? Does this look OK for submission?
Big version: Width: 1024 Height: 683 File size: 726kb
Karl
[Edited 2007-02-01 14:16:40]
JakTrax
Thu Feb 01, 2007 10:17 pm
Hmmm. It looks pretty bad, doesn't it. Looked nice in Zoonbrowser, why so terrible here?
Karl
linco22
Thu Feb 01, 2007 11:01 pm
Hi Karl,
The sky looks pretty bad, almost like you've lightened it too much. You have a dark halo around the tail also.
You can email it to me and I can do an edit and show you my steps if you wish? I can do that this evening when I get home from work. PM me if interested.
Colin
Kukkudrill
Thu Feb 01, 2007 11:06 pm
Looks OK to me when enlarged to its full size ... except for:
(1) noisy sky (looks like it's been sharpened - you need to deselect the sky when sharpening)
(2) a dark halo around the tail (overuse of the shadow/highlight or burn/dodge tool?)
(3) just maybe slightly oversharpened titles esp. the 737-800 logo on the rear fuselage (white halos).
The photo would probably get rejected for reasons 1 and 2, especially 2, but you've come pretty damn close for an editing beginner.
JakTrax
Thu Feb 01, 2007 11:11 pm
OK, how about this one? Different pic altogether.
Big version: Width: 1024 Height: 683 File size: 456kb
I feel it didn't need much editing so all I did was sharpen it a little. Is this ready for submission?
Thanx,
Karl
Kukkudrill
Fri Feb 02, 2007 6:45 am
Looks very good to me. I might try giving it the slightest touch more sharpening, see whether it makes an improvement (it might not).
Charles
Psych
Fri Feb 02, 2007 6:47 am
Karl.
To my eye the sharpening is not right on this 757 - a bit soft still. How are you sharpening?
As in your other post, this one can be improved further - let me know if I can help.
Paul
JakTrax
Fri Feb 02, 2007 11:15 am
Thanks a lot guys, very helpful responses. The above shots were sharpened using the simple 'sharpen' tool, however I've since discovered the 'USM' function, which seems to make a more accurate job. If anyone can give these shots a go I'd be more than grateful - just let me know which file(s) you will require.
Ta,
Karl
monteycarlos
Fri Feb 02, 2007 6:58 pm
Quoting JakTrax (Reply 17):
Don't use that... It will give you too much grain. Only use USM or 'Smart Sharpen'. I go with USM and it tends to work much better.
It's a beautiful night to fly like a phoenix...
aero145
Fri Feb 02, 2007 9:31 pm
Good ol' memories.  Silly Used that function for a *long* time when using the IXUS i camera.
I'm happy you're doing better and better by the day. You'll be good me thinks.
 biggrin
Users browsing this forum: packman and 1 guest
