JetJock22
Comments Please
Sat Feb 03, 2007 5:52 am
bubbles
Crew
RE: Comments Please
Sat Feb 03, 2007 6:02 am
The crop looks a bit odd, especially the first shot.
_Hongyin_
bmibaby737
RE: Comments Please
Sat Feb 03, 2007 6:04 am
Both motive for both; you've cropped too much of the plane(s) off!
Bmi
JetJock22
RE: Comments Please
How is the first one an odd crop? It's showing the nose and a slightly different angle on the fuselage
bmibaby737
RE: Comments Please
Sat Feb 03, 2007 6:06 am
Quoting JetJock22 (Reply 3):
Try and find a very very simular photo on Airliners.net...
You've taken off too much from the left, it's just not attractive.
bubbles
Crew
RE: Comments Please
Sat Feb 03, 2007 6:07 am
If so, it may be rejected due to 'center'.
_Hongyin_
JetJock22
RE: Comments Please
Sat Feb 03, 2007 6:18 am
Here is a question not based on the above photos, but just photos in general. I have a tamron 75-300 lens that I bought way back in 2002. I just recently upgraded to a used but in very good condition Canon 300D. Could it be the lens that is causing some issues, or do you think it is the camera body itself?
LIPH
RE: Comments Please
Sat Feb 03, 2007 6:20 am
Jet,
nice pictures there (some quality issues probably to fix but nothing of impossible), but with quiet an unusual crop....
Ciao
Life sucks. Then you die. Live fast, die young.
JetJock22
RE: Comments Please
Sat Feb 03, 2007 6:23 am
Quoting LIPH (Reply 7):
What do you see and any suggestions on it?
bmibaby737
RE: Comments Please
Sat Feb 03, 2007 6:40 am
Quoting JetJock22 (Reply 6):
Could be a mixture of things, for example settings, weather conditions or your lens.
Your not using Auto, are you?
Bmi
JetJock22
RE: Comments Please
Sat Feb 03, 2007 6:50 am
Quoting BmiBaby737 (Reply 9):
Auto settings or auto focus? I wasn't using auto focus, however i was using the sport auto setting today. I am still not used to manually setting the camera. I need some help with that. I've given it a try a few times, but I just get frustrated with it.
bmibaby737
RE: Comments Please
Sat Feb 03, 2007 7:40 am
Quoting JetJock22 (Reply 10):
I strongly suggest getting advice on Manual settings, and I'd use Auto Focus If I was you, too.
Bmi
flyingzacko
RE: Comments Please
Sat Feb 03, 2007 7:50 pm
It sounds like you definitely need to be using AutoFocus. As far as the manual setting of the camera goes, you don't need to go that far just yet. Try using either the Av or Tv mode where you'll only have to set the desired aperture or the shutter speed. Once you get comfortable with that you might want to shoot manually, but IMO that's a rather tricky business and a light meter is recommended here, I don't see how else you would do it.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
