graphic
I Give Up
Thu Feb 15, 2007 2:50 am
Is there anything that can be done to this?
It has seen soft, then oversharpen, then soft again, then oversharpen again, now its oversharpen, blurry, color, and quality.
http://www.airliners.net/addphotos/r...big/20070214_N218UAarr26DENx3x.jpg
Demand Media fails at life
VICE911
RE: I Give Up
Thu Feb 15, 2007 2:55 am
it's a little blurry towards the tail. maybe you can post the original and someone can have a go at editiding?
Back in China now. Camera used: Nikon D70 D50 D200 D40 FUJI S3 PRO Canon 400D. Now with Nikon D7000.
clickhappy
RE: I Give Up
Thu Feb 15, 2007 2:58 am
Looks like it suffers from a low f/number.
walter2222
RE: I Give Up
Thu Feb 15, 2007 3:35 am
Quoting Graphic (Thread starter):
Did you restart from scratch after the rejection or did you re-edit the previous version? In the latter case, it would be normal because everytime you save as JPEG, you loose quality. On my monitor (not the best) the titles seem over-sharpened and the registration area seems blurry. I like the shot though, with it low evening sun!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
graphic
RE: I Give Up
Thu Feb 15, 2007 3:36 am
I will say this though, I really do appreciate the screeners reply in the e-mail.
If anyone wants a crack, here's the orig:
http://www.airliners.net/uf/536921701/1171478120gSvUvs.jpg
acontador
RE: I Give Up
Thu Feb 15, 2007 3:40 am
Hi Eric,
Quoting Clickhappy (Reply 2):
I have had the same problem, where due to high aperture (low f) part of the airplane was sharp in focus and part slightly out of focus. You can try by careful (and long) use of layers, sharpening the rear part more, but I doubt it will leave the picture 'perfect'. You have to decide whether it is worth the effort.
And even if you get the sharpening part, that's not going to improve the light one that leads to all your other problems (quality, color).
Just sit back, relax and have a glass of Merlot...enjoy your life!
ANITIX87
RE: I Give Up
Thu Feb 15, 2007 5:14 am
Here's my attempt. The back of the aircraft is very blurry, as stated above. I attempted an edit anyway, so here it is.
Big version: Width: 1024 Height: 682 File size: 561kb
With the amount of sharpening I had to add to make the rear of the aircraft acceptable, the image became quite grainy. I'm afraid this one cannot be salvaged, which is a shame as I love the livery, the aircraft, and the lighting.
TIS
dazbo5
RE: I Give Up
Thu Feb 15, 2007 5:24 am
This is about the best I can do. The rear of the aircraft is a little blurry and the overall image is soft, maybe through a little motion blur / camera shake since the shot was taken at 281mm with a shutter of only 1/320th. This is my attempt anyway:
Big version: Width: 1024 Height: 683 File size: 442kb
Darren
ANITIX87
RE: I Give Up
Thu Feb 15, 2007 5:47 am
Wow. I didn't realize how screwed up the colors on my edit were until I saw Dazbo's. Haha.
Ignore mine, then.
TIS
IL76
RE: I Give Up
Thu Feb 15, 2007 5:49 am
Quoting ANITIX87 (Reply 6):
Here's my attempt
Ouch! Autolevels I presume? And a truckload of shadow/highlight. Brr....
Had a go myself...
Big version: Width: 1024 Height: 683 File size: 280kb
It's on the soft-side, but I prefer that over jaggies.
Ed
bubbles
Crew
RE: I Give Up
Thu Feb 15, 2007 5:52 am
The following one is my version.
Big version: Width: 1024 Height: 683 File size: 465kb
N218UA
_Hongyin_
beechcraft
RE: I Give Up
Thu Feb 15, 2007 6:16 am
My Try...
Quite similar to Ed´s approach, but i worked a bit more on the colour of the sky.
To me, it looks a bit more harmonic this way.
Big version: Width: 1024 Height: 683 File size: 499kb
Test Edit
cheers, Denis
That's it! You people have stood in my way long enough. I'm going to clown college!
ANITIX87
RE: I Give Up
Thu Feb 15, 2007 6:25 am
Quoting IL76 (Reply 9):
So it would seem, haha. I apparently went quite wrong. It's a miracle the ones I asked advice on didn't look this bad, if this is what my eye told me to do with this one!
Ed and Darren, I like your edits very much. Graphic, unfortunately none of these seem to be able to save the blurry tail, but if you really want to try and upload this one, go with either Ed's or Darren's. Ed is a screener, after all, so his eye may be best in this case.
TIS
Fiveholer
RE: I Give Up
Thu Feb 15, 2007 6:26 am
Bring back Bethune!
relic
RE: I Give Up
Thu Feb 15, 2007 6:27 am
Ive had the same rejections for soft,then quality/blurry on the re-upload.The problem has been using low F numbers which doesnt help with certain angles of the aircraft.
Andy
clickhappy
RE: I Give Up
Thu Feb 15, 2007 6:43 am
Well, Eric shot it at f/9, which is pretty good considering the light...
Could have been a focus issue, if a left side AF sensor locked on it would cause softness middle-right.
Eric, clean you sensor dood!
relic
RE: I Give Up
Thu Feb 15, 2007 6:44 am
jid
RE: I Give Up
Thu Feb 15, 2007 6:45 am
Yep clean that sensor Eric and check your mail !
Cheers Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
donder10
RE: I Give Up
Thu Feb 15, 2007 9:39 am
Quoting Dazbo5 (Reply 7):
Out of interest, how do you find the EXIF data for this?
Thanks,Alex.
clickhappy
RE: I Give Up
Thu Feb 15, 2007 9:44 am
Don't think motion blur would be a problem (from camera shake), Eric is using a Sigma 80-400 OS if I remember correctly.
You can view the EXIF data using any program that displays such info, I used Nikon View 6, but lots of programs do it.
graphic
RE: I Give Up
Thu Feb 15, 2007 10:34 am
Thanks for the edits guys!
@ Jidd: Got the e-mail, thanks!
@ Ed: That's a nice edit, is there any way to get that bright orange pop back that was the prevailing light at the time? It was a very hazy/smoggy evening and the sun was literally seconds above the mountains at that time.
Quoting Clickhappy (Reply 19):
Yeah but there's no amount of O.S. that could have compensated for me not being able to feel my fingers at that point  cold
Thanks again for all the help, it's much appreciated!
P.S. The sensor shall be cleaned in short order  Wink
Boston92
RE: I Give Up
Thu Feb 15, 2007 1:18 pm
My Version:
Big version: Width: 3097 Height: 1774 File size: 692kb
NicolasRubio
RE: I Give Up
Thu Feb 15, 2007 1:45 pm
I had a go too...
http://img157.imageshack.us/img157/2114/117148394758bpuiax7.jpg
Nicolas Rubio
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
graphic
RE: I Give Up
Thu Feb 15, 2007 2:53 pm
http://www.airliners.net/uf/view.fil...1701&filename=1171518643xihftK.jpg
Better? Worse? Thoughts? I like it because it accurately shows the orange pop coming from the low sun shining through the Brown Cloud, and I used a different sharpening technique that I think helped me sharpen the rear section much better, while keeping the rest of the aircraft from becoming oversharpened.
Hows this one?
IL76
RE: I Give Up
Thu Feb 15, 2007 4:17 pm
Quoting Graphic (Reply 20):
Well, I didn't do anything to the colours. I just moved the 'white' slider in the levels histogram closer to the left (I think it was +/- 210). If you want more orange, you'll have to play a bit more with the levels of the R, G or B.
Although not shockingly disturbing, I forgot to reduce the jaggies on the leading edge of the wing though.  Smile
Ed
skidmarks
RE: I Give Up
Thu Feb 15, 2007 4:36 pm
What a good thread to show the many different takes each individual has on a picture. Just goes to show how difficult a screeners job is. Keep up the good work boys and girls! Big grin
Andy
Growing old is compulsory, growing up is optional
beechcraft
RE: I Give Up
Thu Feb 15, 2007 6:35 pm
Eric,
you´re last try isn´t bad. But i´d consider to upload it at 1024x XXX. There also is a bit of noise on the engine Cowling and the surrounding area.
The sky has a slight green cast to me, i got rid of that in my edit (reply 11) with selective colour correction. I may have overdone it just a little bit, but it looks more harmonic, regarding the orange light conditions on the 777 front.
Denis
OD720
RE: I Give Up
Thu Feb 15, 2007 7:04 pm
Here's my go.
Big version: Width: 1024 Height: 685 File size: 193kb
trvyyz
RE: I Give Up
Thu Feb 15, 2007 10:18 pm
Since everyone is playing with the shot,me too.
Big version: Width: 1024 Height: 734 File size: 287kb
flyingaway
RE: I Give Up
Thu Feb 15, 2007 11:25 pm
Hey I also couldn't resist!
Big version: Width: 1024 Height: 683 File size: 521kb
my try
graphic
RE: I Give Up
Fri Feb 16, 2007 2:29 am
http://www.airliners.net/uf/view.fil...1701&filename=1171560439y973HN.jpg
@Denis: Got rid of some of the noise and some of the green and resized it to 1024, this is all re-working from the original.
@Everyone else: Thanks and Keep 'em coming!
relic
RE: I Give Up
Fri Feb 16, 2007 2:43 am
OD720
RE: I Give Up
Fri Feb 16, 2007 3:59 pm
Now that we had quite some fun with the photo, can the screeners point us if any of the edits would be accepted?
beechcraft
RE: I Give Up
Fri Feb 16, 2007 6:30 pm
Eric,
i´d say, try your last edit. it looks quite good to me.
Also leave a note to the screeners about what you have done.
Denis
graphic
RE: I Give Up
Mon Feb 19, 2007 4:57 am
http://www.airliners.net/addphotos/big/ready/qbdive.jpg
Thanks for all the advice and edits guys! Lets see how she shapes up eh?
graphic
RE: I Give Up
Sat Feb 24, 2007 1:52 am
Well that's it, I'm done tryin with this pic.
