LIPH
Help With Motive Rej
Mon Feb 26, 2007 7:40 pm
Hy there,
have recently received the following rejection (quality and motive) :
http://www.airliners.net/addphotos/r...a_la_maddalena_al_finger_a_vce.jpg
Apart from the quality issue, I'd like to understand if the bad motive is due to the crop or to the "mobile finger" to the left of the aircraft which, apparently, do not influence the visibility of the aircraft. I recently saw a couple of "finger shots" on the db, so this possibility looks strange...
Thanks for any help.
Ciao
Life sucks. Then you die. Live fast, die young.
JRadier
RE: Help With Motive Rej
Mon Feb 26, 2007 7:53 pm
Quoting LIPH (Thread starter):
It are just stairs, nothing more nothing less  Wink. They do however block a pretty big portion of the aircraft (you can see a lot of wing and engine through the stairs which has yielded you this motive rejection. If you would have waited a bit until they were removed it would have been a lot better (Apart from the fact it's backlit, which doesn't exactly helps either)
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
LIPH
Mon Feb 26, 2007 8:50 pm
Quoting JRadier (Reply 1):
Yes, it make sense. Anyway, are now finger shots ok on A.net ?
Ciao
IL76
Mon Feb 26, 2007 9:27 pm
It's about a combination of things... Messy surroundings, backlit and quality problem (green fringing, overexposed top). Which makes us question the motive for (uploading) this photo.
E
Stealthz
Mon Feb 26, 2007 10:04 pm
Quoting IL76 (Reply 3):
So the rules are being made up as you go along?
globalpics
Mon Feb 26, 2007 10:07 pm
No all of the above problems are clearly backed up in the rejection listing, take a look......
IL76
Mon Feb 26, 2007 10:34 pm
Quoting StealthZ (Reply 4):
Because we screeners question the motive of a photo for numerous reasons, we reject it. What do you mean by 'making up rules'? Could you elaborate?
E
PS: In the motive rejection reason text: "Please note that motive rejections can also result from other, more subjective reasons. These are usually of an aesthetical nature".
[Edited 2007-02-26 14:37:52]
ThierryD
Crew
Mon Feb 26, 2007 11:18 pm
More on motive rejections:
http://planecatcher.com/IGRR.htm#Motive
Eduard, Globalpics you're more than welcome to contribute feedback to the guide!  Wink
Thierry
"Go ahead...make my day"
LIPH
Mon Feb 26, 2007 11:30 pm
Ed,
I see the point. Now it's clear. Thanks for feedback.  thumbsup
What about finger shots ? Is anything changed as general rule of acceptance ?
Ciao
Users browsing this forum: Borut and 1 guest
