LAXspotter
Good Quality, But Motive...
Thu Mar 01, 2007 3:17 am
I believe these two shots are great quality however there could be a motive reject
1. http://www.airliners.net/uf/536924396/1172451315ayrsYL.jpg
2. http://www.airliners.net/uf/536924396/1172450524OSVZcW.jpg
Need some tips on editing, particularly cropping.
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
Fly747
RE: Good Quality, But Motive...
Thu Mar 01, 2007 3:26 am
Although I like the close-up, the Airbus is blurry and the 757 is out of focus.
Ivan
viv
Thu Mar 01, 2007 4:41 am
The quality is not great. Both shots are soft - the Airbus might be salvageable but the 757 is a case of camera shake and cannot be saved.
The Airbus would be rejected for motive - the crop s awkward and, for example, cuts a slice off the engine intake for no good reason.
When you crop, the boundaries of the cropped shot should be coherent, i.e. little bits of the aircraft should not be accidentally cut off.
TedTAce
Thu Mar 01, 2007 4:46 am
I think the motives are fine. The main problem is these are apparently off the stick shots. You should at lest try to do some editing before having them looked at...
This space intentionally left blank
Lanas
Thu Mar 01, 2007 7:27 am
On the Aer Lingus shot the light won´t be in your favour, since the backlit issue may cause grain when sharpenng. On other aspect I think it´s blurry, but may be saved with a proper edit. As for the motive, I think it doesn´t stand a chance. Like Viv said, the engine is cut and also I guess it wouldn´t be that nice if you left only the forward fuselage section.
The AA shot is too blurry (out of focus) and I don´t think it can be saved. You may be lacking some contrast here, too.
It would be better if you posted your edits instead of the original versions next time. You might get better tips in order to improve your editing skills.  Wink
Hope it helps.  Smile
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
eadster
Thu Mar 01, 2007 7:46 am
Quoting Viv (Reply 2):
Agreed, but they look to be originals however, so they won't do any good in their current states.
I've had a quick play with them. The 757 is not good. Its too overexposed, the other is backlit, and has a blurry nose area.
Better luck with your next shots.
flugnord
Thu Mar 01, 2007 8:14 am
Oh, I just have to say this. Mella, as stands on the Airbus means a whore in Icelandic...
I actually started crying because it was so funny. Well, now you know.
Hehehe.  rotfl
JRadier
Thu Mar 01, 2007 8:17 am
Quoting Flugnord (Reply 6):
I guess this is one of those 'you must have been there' moments
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
eadster
Thu Mar 01, 2007 8:30 am
Its OK, He'll come right eventually!
JeffM
Thu Mar 01, 2007 9:24 am
Quoting LAXspotter (Thread starter):
not 'great'....more like O.K.
What wb setting did you use to get a turquoise sky? You were right about the poor motive.
tom3
Thu Mar 01, 2007 9:44 am
Hello
Did a quick edit of the AA 757
http://www.airliners.net/uf/536884424/1172709733AgEFbZ.jpg
For me it looks not so bad..
Tom
Tom Mousel - Lap
