Fly747
Rejection Question
Fri Mar 09, 2007 9:23 am
I got this one rejected for overexposed and quality. Now the exposure looks good on my screen, I don't see any loss of detail on the airplane or blown out areas.
I am on an LCD and got used to seeing things bright. I got a few dark rejections when I switched to an LCD so now I know that a bit brighter image should be good to go. Is it really way too bright this time?
I think it could use a touch of contrast boost though.
Thanks.
Ivan
chris78cpr
RE: Rejection Question
Fri Mar 09, 2007 6:27 pm
It doesnt look overexposed to me but then again i am on a laptop right now. For me it is bright but not too bright, it might be due to my laptop tho.
Chris
[Edited 2007-03-09 10:46:34]
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
LIPH
Fri Mar 09, 2007 6:34 pm
Quoting Fly747 (Thread starter):
It is. It's overexposed, oversharpened and oversaturated...It looks like you used the shadow-highlight tool of PS a bit too much. I would re-edit from the beginning...
Ciao
Life sucks. Then you die. Live fast, die young.
eadster
Fri Mar 09, 2007 6:48 pm
Looks ok to me too.
Was there snow on the ground? Because from what I see, there are no real traces of Shadow/Highlight used, but more signs of reflection from snow.
chris78cpr
Fri Mar 09, 2007 7:09 pm
Quoting Eadster (Reply 3):
thats what i thought it looked like.
chris
Fly747
Fri Mar 09, 2007 11:10 pm
Yes, lots of snow on the ground. I shot this in Manual mode and got readings from my Sekonic light meter which is quite accurate. No Shadow/Highlight tool was used during editing, no need for that...
Thanks for your replies guys so far.
Ivan
psyops
Sun Mar 11, 2007 2:47 am
Hey Ivan - long time no see.
I have the same reg captured coming into YMM. These aircraft I never seem to get the same colors - very dependent on lighting. Here it is:
Photo © Peter Nickerson
Mine is a winter shot as well, the approach is over a field that is covered in snow that is never touched. I seem to have more contrast (less light on the underside), mine does seem a bit darker, but not overly so.
For my eyes if you boost the contrast it would be alright.
Pete
carlos
Crew
Sun Mar 11, 2007 4:29 am
Hello Ivan,
it looks on my EIZO also overexposed. You can check the Histogramm in PS and you will the problem.
I agree with LIPH, the photo is a little bit oversharpened (look at the area around the left wheel for example).
Greetings Klaus
