dvincent
New Plane For An Airline... This Shot Good Enough?
Fri Mar 16, 2007 1:51 am
Hey guys, figured I'd ask if I got it right on this one.
http://www.airliners.net/addphotos/big/ready/n101hq.jpg
It's the first ERJ-175 for Republic (USAirExpress) and I was wondering if it had the quality for the DB. It was taken about an hour before sundown and I think the warm light gives it a nice touch but a screener might disagree.
From the Mind of Minolta
ANITIX87
RE: New Plane For An Airline... This Shot Good Enough?
Fri Mar 16, 2007 2:02 am
Too sharp, and too grainy. Even if you bring down the sharpening, this one may get a quality rejection. Did you sharpen the sky? It looks like you may have.
TIS
dvincent
Fri Mar 16, 2007 2:14 am
Quoting ANITIX87 (Reply 1):
I did not in fact. I only did one pass of USM on the fuselage, 50% at 1.2 and I also transparent masked off the cheatlines and the USAir logo. I did not use any noise reduction on the sky. JPEG might be a factor here, I saved at the highest quality but even then it sometimes brings out otherwise hidden sky grain, comparing my TIFF file to the resultant JPEG at 500%. I may have to do some extra noise reduction on the sky to keep that from happening (I usually do very little since I shoot at ISO 100 or 200).
I use a tube monitor (LaCie Electronblue IV), so my "conservative" (at least, I thought it was!) sharpening probably might be too much for an LCD screen. I backed off of the sharpen layer a bit and did some noise reduction on the sky, here's the result.
http://homepage.mac.com/kefkafloyd/.Pictures/n101hq_2.jpg
Thanks for the look Antonis.
[Edited 2007-03-15 19:15:36]
[Edited 2007-03-15 19:18:29]
TransIsland
Fri Mar 16, 2007 5:57 am
Sky looks fine here, but the plane is way oversharpened, especially - but not limited to - registration, tail logo and the transition from shadow to sunlight under the wing... major jaggies.
I'm an aviation expert. I have Sky Juice for breakfast.
dvincent
Fri Mar 16, 2007 7:13 am
Big version: Width: 1024 Height: 681 File size: 318kb
(click for fullsize)
I reprocessed the image from scratch. I backed off sharpening almost completely and did some light spot softens, but the image is bordering on soft to me now on my LaCie. I'm looking at it on my laptop and I can kind of see where rev2 could be oversharp but if this is the line to tread it's pretty baffling. I do PS for a living for print and these lower resolution (by comparison) web files have a much smaller margin for error, apparently, especially across monitors.
Maybe a 1280 wide resolution would help? It seemed to make a difference for this shot in the DB of the same aircraft (but it had a test reg at the time) which I was using as a comparison target for sharpness on the color scheme.
Again, thanks for the input. It's much appreciated.
Silver1SWA
Crew
Fri Mar 16, 2007 7:23 am
Quoting Dvincent (Reply 2):
I suggest trying .2 or .3.
flyingzacko
Fri Mar 16, 2007 6:51 pm
Quoting Silver1SWA (Reply 5):
Yup, 1.2 is way too much.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
dvincent
Fri Mar 16, 2007 11:17 pm
Quoting FlyingZacko (Reply 6):
That's the amount I was using on the high-res image which I then downsampled to upload. 1.2 on a 300DPI 7x6 isn't all that much. I sharpen and then downsample, perhaps I should do it the other way round? Saving downsamples for last is generally the way we do in prepress. I did that with the latest one and only used a tiny amount of USM. Maybe that's the way I'll go now. Thanks for the help.
dvincent
Sat Mar 24, 2007 11:01 pm
Hey guys, I wanted to say thanks for the help. It did get in. Big grin
http://www.airliners.net/open.file/1191427/M
flyingzacko
Sat Mar 24, 2007 11:32 pm
Quoting Dvincent (Reply 7):
Sharpening should be done after resizing the image, usually as a last step of post-processing.
Congrats on getting the pic in man.
Sebastian
[Edited 2007-03-24 16:32:45]
aviator1990
Mon Mar 26, 2007 2:39 am
The link does not show the photo.
Alibo5NGN
Mon Mar 26, 2007 4:51 am
Quoting Aviator1990 (Reply 10):
Yes it does.
Congrats Dan.
It takes knowledge to make a career. It takes wisdom to live a life.
dvincent
Mon Mar 26, 2007 9:35 am
Sure you guys are clicking the right link? The photos earlier in the thread have since been deleted.
Quoting Dvincent (Reply 8):
That's the one you should be looking for. If that's not working, then I don't know what to say.
[Edited 2007-03-26 02:35:35]
Fly747
Mon Mar 26, 2007 10:50 am
And the proper way of linking photos...
Photo © Dan Vincent
Ivan
