Karlok
Advice For Photos In Queue
Thu Mar 22, 2007 1:38 am
eddl
RE: Advice For Photos In Queue
Thu Mar 22, 2007 2:14 am
1, 2, 3, 4 + 6: aircraft too low in the frame
5: the KLM tail logo may help here
Phil / EDDL
Karlok
Thu Mar 22, 2007 2:38 am
All (except 5) to low in frame? What is considered as low? Should I centre the fuselage in the frame?
Regards / Karlok
eddl
Thu Mar 22, 2007 2:59 am
Looks much better this way (also the "a.net way"):
http://www.eddl-photography.de/misc/karlok.jpg (hope you don't mind)
The vertical center line is usually right on the upper 1/3 part of the fuselage (on the windows or slightly above the windows, depends on aircraft). This way the aircraft looks correctly centered with the rear end (fin) in mind. Do not center the aircraft exactly, like this: space above the fin = space below the gear/fuselage. This is important for side shots; in pic #2-6 it's slighty different. If you want to include the whole fin, crop as tight as possible (leave a few pixels though  Wink ) in the upper part, so that the fuselage is in a more centered position.
Nice shots btw.  Smile
Hope this helps,
Phil / EDDL
INNflight
Thu Mar 22, 2007 3:22 am
Two, three and four are centered ok at be accepted. It's not slide shooter centering, but with more or less equal space below and above the aircraft, hence they should be fine.
Florian
Jet Visuals
Karlok
Tue Mar 27, 2007 6:44 pm
Quoting EDDL (Reply 1):
All accepted, except for #5. rejected for motiv, with a personal message: akward crop of the fin..
Users browsing this forum: Johner and 10 guests
