opso1
Dirty?
Tue Mar 27, 2007 12:42 am
http://www.airliners.net/addphotos/r...tions/big/20070325_ze418lstaaa.jpg
I can't see how this has been rejected for being dirty- please help... Should I appeal?
Thanks in advance for your comments.
OPSO1
Shep
RE: Dirty?
Tue Mar 27, 2007 12:56 am
Big spot between tail and top edge.
JeffM
RE: Dirty?
Tue Mar 27, 2007 12:59 am
Quoting Opso1 (Thread starter):
Should I appeal?
maybe after you fix the dust spots, fix the level issue too.
LIPH
RE: Dirty?
Tue Mar 27, 2007 1:00 am
OPSO,
yes : over the main rotor are present many black spots and also over the tail one is present. Check with PS : equalize the image and they'll turn out.
Ciao
Life sucks. Then you die. Live fast, die young.
opso1
RE: Dirty?
Tue Mar 27, 2007 1:20 am
Thanks, I couldn't see them...
OPSO1
EK20
RE: Dirty?
Quoting JeffM (Reply 2):
and the brightness levels.
 Smile
IFRFlightPlan
RE: Dirty?
Tue Mar 27, 2007 5:25 am
Ok maybe I am blind here, but i do not see anything wrong with this photo, nor do i see spots, anyone want to point them out to me.
John
LIPH
RE: Dirty?
Tue Mar 27, 2007 5:47 am
Quoting IFRFlightPlan (Reply 6):
Well,
black spots are very difficult to see just with eyes (only screeners are trained to so so Wink). I always try to use PS in order to make them to turn out....
Ciao
opso1
RE: Dirty?
Tue Mar 27, 2007 6:37 am
If, as has been pointed out above, photos have to be converted to see the spots, are the screeners are being too picky? Surely "normal" viewers would be none the wiser??
OPSO1
clickhappy
RE: Dirty?
Tue Mar 27, 2007 6:41 am
I screen in a completely dark room, such dust spots are easy to spot.
If we opened each image up in Photoshop I would screen 1/5 the amount I do (about 200 photos a day currently).
bubbles
Screener
RE: Dirty?
Tue Mar 27, 2007 6:51 am
Quoting Opso1 (Reply 8):
I am not in a dark room now, but I could clearly see it without dragging the image into Photoshop.
FYODOR
RE: Dirty?
Tue Mar 27, 2007 7:32 pm
Opso1,
There is a spot you can see even without PS but I understand why you miss it - it is not easy to see by fleeting glance.
To prevent cases like that I'd recommend you yo use Equalize (Image - Adjustments) option at PS. Do not neglect this option at the future - always good to check your picture. It will help you to clearly see spots like that and at least will give you the good signal if you need to clean your matrix (if the same spot is at the other pics it is looks as your matrix is a bit dirty).
Fyodor
TupolevTu154
RE: Dirty?
Wed Mar 28, 2007 2:24 am
Here's the equalized image. Dust spots are far easier to see.
http://img.photobucket.com/albums/v476/Toml/20070325_ze418lstaaaequalized.jpg
Tom Big grin
Users browsing this forum: No registered users and 9 guests
