flamedude707
Spotting At ORD T5
Wed Mar 28, 2007 12:24 pm
How is the spotting inside ORD terminal 5, the international one? Are there any good spots airside? Also, do can you transfer to the other terminals without having to clear security again?
Time you enjoy wasting, is not wasted.
mke717spotter
RE: Spotting At ORD T5
Fri Mar 30, 2007 4:13 am
Your not going to have any success spotting inside the terminal, unless you have a borading pass. They don't let you go into the gates area unless you have a boarding pass. I'm guessing if you do have a pass there should be some pretty decent views from the gates area. About your other question, if you go from one terminal to the other your going to have to go through security again. Hope this helps.
