kimv777
Is This Ok Quality?
Thu Mar 29, 2007 7:21 am
Hello.
I just wondering if these pictures are good, ore what i can do to improve them?
1.
Big version: Width: 1024 Height: 510 File size: 534kb
2.
Big version: Width: 1024 Height: 517 File size: 317kb
All response is appreciated.
Regards:
Kim.
LIPH
RE: Is This Ok Quality?
Thu Mar 29, 2007 7:29 am
Kim,
are these original sizes ?
- The first one suffer from an odd crop and is also soft. A motive rejection then will surely be on the way. Why did you crop the nose that way ?
- Same for the second, even if the motive could be acceptable if the quality and the crop would be good. The aspect ratio for the picture must bemaintaned to the 3:2 standard. Yours is wierd.
Ciao
Life sucks. Then you die. Live fast, die young.
kimv777
Thu Mar 29, 2007 7:34 am
No, this is not the orginal size.
chris78cpr
Thu Mar 29, 2007 7:48 am
I think both will get rejected for quality as there is a lot of grain, they are soft, too much contrast and are dark.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
JeffM
Thu Mar 29, 2007 7:52 am
They will get rejected for size. The aspect ratio is wrong.
kimv777
Thu Mar 29, 2007 8:18 am
Now I have done some changes to the picture size. is this better?
Big version: Width: 1024 Height: 682 File size: 690kb
Big version: Width: 1024 Height: 682 File size: 415kb
But can i do something about the quality and grain?
Regards:
Kim
JetJock22
Thu Mar 29, 2007 8:21 am
What iso speed are you shooting at?
kimv777
Thu Mar 29, 2007 8:39 am
On the first picture it's ISO 800 and the second it's ISO 200.
Regards:
Kim
JetJock22
Thu Mar 29, 2007 9:03 am
Quoting KimV777 (Reply 7):
That's part of the problem. Your iso should right around 100. Those speeds are too high and are causing your grain.
LIPH
Thu Mar 29, 2007 4:55 pm
Quoting KimV777 (Reply 5):
Kim,
I don't think you can do much to imporve the quality there : a re-edit will surely brings the quality up, but not up to A.net standards....Remember always to shoot at the lowest ISO setting possible.
Ciao
