JohnJ
Bad Editing?
Fri Mar 30, 2007 1:42 am
Just got the following image kicked for bad editing:
http://www.airliners.net/addphotos/rejections/big/20070329_af_fgspc_ain_1779.jpg
While I can't specifically recall what I did to this shot, for a simple overhead shot like this my normal workflow would have been to touch up dust spots (I have one pesky one that I can't get rid of), adjust the levels, then crop. I may have also used the white balance tool in the raw editor as well, but again I can't specifically recall. The shot didn't make it past the first round of screening, so there must be something pretty obvious that I'm missing.
In my mind, the two actions that I took that could have resulted in the editing reject are the white balance adjust and dust spot touch-up, but to my eyes things look OK in those areas. I'd like to re-submit the shot, but unless I know what to fix I don't see the point. Any thoughts?
clickhappy
RE: Bad Editing?
Fri Mar 30, 2007 1:51 am
very obvious use of the Shadow/Highlights tool under the wing.
The tool has worn away the reg and you can see where the tool was not used in the area of the wing closest to the engine pylon.
acontador
RE: Bad Editing?
Fri Mar 30, 2007 1:52 am
Hi John,
My guess would be the sky. On close scrutiny it shows a lot of 'artifacts' (sometimes wrongly referred to as 'too much JPG compression'), like you adjusted too much levels (including the sky) and maybe on top of that sharpened the sky, too.
Edit: Too slow, Royal beat me! There is a reason why he's a screaner...
[Edited 2007-03-29 18:55:30]
Just sit back, relax and have a glass of Merlot...enjoy your life!
JohnJ
RE: Bad Editing?
Fri Mar 30, 2007 5:13 am
Quoting Clickhappy (Reply 1):
Actually, not. I have no idea how to use the Shadow/Highlights tool or where I'd even find it.
clickhappy
RE: Bad Editing?
Fri Mar 30, 2007 5:19 am
Hi John. I don't really know what to say. That was my first thought when I viewed the large image you provided in this thread.
Nothing to loose by appealing it, perhaps with a note that no editing was done.
Either that or maybe someone can help you with the original file. If you shot Nikon, or in JPEG I would be willing to have a go at it.
Cracking image, by the way.
Royal
Ander
RE: Bad Editing?
Fri Mar 30, 2007 5:54 am
I wouldn't say it is that obvious. My guess is that AF maintenance covered the reg area when painting thus leaving a different tone area.
Ander
Born to tri.
Psych
RE: Bad Editing?
Fri Mar 30, 2007 5:57 am
Quoting JohnJ (Reply 3):
I can believe that John. It does not surprise me that Royal pointed out the underside of the wing, as many of the screeners focus a lot on contrast issues and I know there is a general dislike of that tool in PS. But we cannot underestimate the effect of lighting in particular circumstances. I have a shot where many might be concerned about the use of that tool - I have never used it myself either - and the effect of the lighting in the photo below is solely due to the high reflectance of the surface that day; in my case due to the angle of the sun and snow on the ground - nothing to do with editing:
Photo © Paul Markman
I think the editing rejection is harsh.
Paul
JRadier
RE: Bad Editing?
Fri Mar 30, 2007 6:18 am
Quoting Psych (Reply 6):
I think that it isn't as bad (PS3/LR have it in the raw converter now as well), but more the way it is used. It is a very powerful tool that can yield excelent results if you know how to use it.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
JohnJ
RE: Bad Editing?
Fri Mar 30, 2007 8:06 am
Quoting Clickhappy (Reply 4):
Not a problem - and thanks for replying to my thread (thanks everyone else, too, for the input). Perhaps the easiest thing to do at this point is use another shot from the sequence - I clicked off 4-5 of them and they all turned out OK.
Users browsing this forum: MadridSpotter and 2 guests
