gerardonava
Your Input Is Appreciated
Tue Apr 03, 2007 3:29 pm
I took this photo the same day I took the photo of the A380 in LA. What do you think I could do to improve this shot? Weather was pretty awful that day, however, I live 3 hours away from LAX and this was my only opportunity to shoot at this airport.
PS: I just read the thread about Alaska Air and Horizon photographs in the db. wow, talk about bad timing. If this post is in any ways violating the new policies feel free to remove.
[Edited 2007-04-03 08:46:15]
[Edited 2007-04-03 08:46:44]
aussie18
Crew
RE: Your Input Is Appreciated
Tue Apr 03, 2007 6:17 pm
looks abit soft in parts,like tail,horizon titling,under wing and also some noticable jaggies around the nose already.
monteycarlos
Tue Apr 03, 2007 8:54 pm
Quoting Aussie18 (Reply 1):
I'd agree here... Hit it with more USM but make sure to erase the nose jaggies and any others that may appear along the upper forward fuselage as you go.
It's a beautiful night to fly like a phoenix...
bubbles
Crew
Tue Apr 03, 2007 9:06 pm
I think the original photo is slightly blurry, especially the tail. If you gave more USM to conquer the blur, the jag might appear.
_Hongyin_
Lanas
Tue Apr 03, 2007 11:26 pm
I agree with the soft/blurry issue. I´m afraid also that the bright background won´t help at all. The aircraft looks dark in places, and a little flat. If you try to increase the brightness the intense background will play against you.
I´d place the aircraft just a little higher in the frame, maybe.
Hope it helps.  Smile
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
bubbles
Crew
Tue Apr 03, 2007 11:58 pm
And one more - the current image has looked grainy. If more USM were given, the grain, especially appearing at the belly, would be getting deteriorated.
_Hongyin_
