damien846
I Like This Shot But...........
Wed Apr 04, 2007 2:41 am
I took this shot at RAF Musuem at Hendon back in January. All I have done is a little editing. Size crop etc.
But I can't get the Shapness right? The Reg under the wing does not look right?
Big version: Width: 1024 Height: 683 File size: 555kb
Can anyone help or is it not worth it?
Damien
bmibaby737
RE: I Like This Shot But...........
Wed Apr 04, 2007 3:11 am
Looks good apart from it's unlevel and possibly slightly overexposed near the rear... ?
Bmi
Lanas
Wed Apr 04, 2007 3:34 am
Looks good to me either, and I agree on the overexposed issue too.
However, how do you notice if it´s unlevel in this case?
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
eadster
Wed Apr 04, 2007 8:16 am
A small adjustment on the shadow/highlights tool should fix that. I'd apply a tad more USM but other than that I think its fine.
As for level, I have no idea on what to use as reference. I'd probably get rid of some of that space at the front of the aircraft too so its the same as the rear. You'll get a centre otherwise!
Lanas
Wed Apr 04, 2007 12:44 pm
Quoting Eadster (Reply 3):
Forgot about that.  checkmark
Cheers!
Lanas.-
damien846
Wed Apr 04, 2007 5:28 pm
Next silly question what is USM?
Damien
bmibaby737
Wed Apr 04, 2007 6:09 pm
Quoting Damien846 (Reply 5):
Unsharp Mask
damien846
Wed Apr 04, 2007 7:27 pm
Of course it is! Silly me!
I had tried that but could not get it any better! I will however try again!
eadster
Wed Apr 04, 2007 8:40 pm
My settings are as follows:
Amount: (adjust to what you think. Usually a reasonably high setting)
Radius: 0.2 pixels
Threshold: 0
This may help you out a bit!
Lanas
Wed Apr 04, 2007 8:58 pm
Quoting Eadster (Reply 8):
Radius: 0.2 pixels
Threshold: 0
Exactly like mine. I find the 0.2 pix radius very suitable and not so 'aggresive'. I use a reasonably high amount (400-500%) for my first pass of sharpening, then work on something lower for the following pass.
Hope it helps.  Smile
Cheers!
Lanas.-
bmibaby737
Wed Apr 04, 2007 9:39 pm
Radius: 0.2 pixels
Threshold: 0
I too would recommend those settings! I use 0.3, however.
