linco22
Contrast Rejection
Thu Apr 05, 2007 2:25 am
HI all,
Is there a problem with the contrast on this shot, as I really don't see it.
http://www.airliners.net:80/procphot...404_bmia319gdbcgatbhd250307_03.jpg
Colin
bubbles
Crew
RE: Contrast Rejection
Thu Apr 05, 2007 2:35 am
Hello Colin
It looks hazy and flat.
_Hongyin_
garry
Thu Apr 05, 2007 2:47 am
Hi Colin - hope you are well.
Having took it quickly into CS2 it does seem to benefit from a 'slight' curves adjustment to provide a little boost in the contrast.
Nice shot nevertheless.
Garry
www.garryridsdale.com
dendrobatid
Thu Apr 05, 2007 3:08 am
Colin,
The contrast is too low. If you look at what you should expect to be the blackest of blacks, it is not, it is a smoky dark grey.
Using levels I suspect a small gap at the left of the histogram. Pull the left slider in a lttle and I am certain that it will improve. Alternatively, as Garry suggests use the curve to the same effect
Mick Bajcar
linco22
Thu Apr 05, 2007 4:12 am
Thanks chaps,
Been shooting RAW over the last six months, so didn't quite get this one right.
I'll re-edit
Thanks again
Colin
Users browsing this forum: rjsampson and 1 guest
