damien846
Is The Crop/Motive OK On This Shot?
Sat Apr 14, 2007 1:02 am
Big version: Width: 1024 Height: 683 File size: 689kb
Hello again All,
Once again I need advice on this shot. Also is it a bit over sharpe?
Still got loads to learn ref editting!
Damien
boeingfreak
RE: Is The Crop/Motive OK On This Shot?
Sat Apr 14, 2007 1:09 am
Hi,
I'd crop it closer on the right side, it looks kind of cut off now. It is also a bit low in frame for my taste.
Hope this helps,
Florian  wave
AC773
Sat Apr 14, 2007 1:10 am
The first thing I notice here is that you've slightly clipped the horizontal stabilizer. This is just my opinion of course, but I think you should either leave some more space on the right to let it show or cut off more of it and go all the way with centering the fuselage. Personally, I don't like to see it done halfway.
Good job though Damien, I'm seeing very visible progress compared with some of your last shots. Keep it up!  bigthumbsup
Better to be nouveau than never to have been riche at all.
bubbles
Crew
Sat Apr 14, 2007 2:39 am
Hello Damien
I'd suggest keeping that stabilizer in the frame. By the way, the photo looks slightly soft. And the nose is a bit hot.
_Hongyin_
damien846
Sat Apr 14, 2007 4:18 am
Thanks for the advice.
Quoting Bubbles (Reply 3):
Understand the hot nose. But not sure what you mean ref slighly soft?
here is a second attempt at an edit.
and below the orignal!
Big version: Width: 1024 Height: 683 File size: 781kb
Big version: Width: 1024 Height: 683 File size: 577kb
JeffM
Sat Apr 14, 2007 4:25 am
How many more pictures of that plane do you have?  rotfl  You should branch out a little.
damien846
Sat Apr 14, 2007 4:34 am
Quoting JeffM (Reply 5):
Taken on this day? About 30? Would you like to see them all!
 biggrin
