Smalbany
Centering Rejection Worth Fixing?
Mon Apr 23, 2007 3:57 am
The reason for the following rejection was for centering
http://www.airliners.net/addphotos/r...g/20070422_N659CA_ALB_041107_2.jpg
I guess that this was because it needs to be cropped more tightly on the right side? I left more space around the edges because I thought that the WN 737 getting hosed in the background was interesting. I guess the question is; should I see if I can crop with a little more space on the left, crop my normal way and eliminate the deicing operation, or just forget it all together.
Just looking for some opinions. I'm not big fan of getting multiple rejections on one shot.
Dan
jetmatt777
Crew
RE: Centering Rejection Worth Fixing?
Mon Apr 23, 2007 4:04 am
It's an awesome shot w/ out the WN737, IMHO, Crop it normally and you'll be fine I think.
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
CalgaryBill
Mon Apr 23, 2007 4:58 am
Quoting Jetmatt777 (Reply 1):
 checkmark
It also appears a bit dark, but I'm on my uncalibrated laptop right now so take that with a grain of salt. Nice, low angle light on the plane though!
B
FlightShadow
Mon Apr 23, 2007 7:00 am
Yeah, re-crop it if you've got the quality. The Delta Connection titles can be a pain in the APU to sharpen - I'm in SLC, I know  Wink It also does look a tiny little bit dark - if you can brighten it a little bit, do that as well.
"When the tide goes out, you can tell who was skinnydipping."
Smalbany
Mon Apr 23, 2007 10:31 am
Thanks for the responses!
I'll give a re-edit a stab.
Lanas
Mon Apr 23, 2007 2:29 pm
Hi Dan
You should focus in the subject of your picture when centering. It´s a pity, since the de-icing operation might be interesting, but I guess it won´t be an appealing composition for your pic.  worried
In other issues, I see your photo a little blurry, specially on the tail. See if you can get that, too.  bigthumbsup
Cheers!  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
