flamedude707
What To Do To Get This To A Net Standards?
Tue Apr 24, 2007 2:55 pm
This is an unedited version (resize only) of a shot. What things in the editing process should be done to get this acceptable for A.net?
Big version: Width: 1024 Height: 666 File size: 421kb
Time you enjoy wasting, is not wasted.
eadster
RE: What To Do To Get This To A Net Standards?
Tue Apr 24, 2007 3:38 pm
Depending on the quality of the original....
1. Level it.
2. Remove colour cast.
3. Crop it (make sure aircraft is centred).
4. Check for dust spots.
5. Sharpen it.
EK20
Tue Apr 24, 2007 4:05 pm
Was it taken through a glass window? There is an overall wierd look to the colour.
ThierryD
Crew
Tue Apr 24, 2007 4:46 pm
Had a quick play with it:
Big version: Width: 970 Height: 644 File size: 419kb
Ashwin's photo
The following editing was done in the mentionned sequence:
- Cropped and resized
- Removed dustspots
- Corrected levels (highlights vs dark areas compensation)
- removed color cast
- added some saturation
- lighting/contrast
- sharpening
The photo might stand a chance but as Martin already said it depends on the quality of the original; the major problem with your shot is primarily the high sun which renders the top of the plane very bright vs the underside being very dark and secondarily the shooting through some glas which gave it this awful color cast which costs photo quality when you correct it.
Good luck!
Thierry
"Go ahead...make my day"
flamedude707
Wed Apr 25, 2007 8:34 am
Here is another edit of it. Tell me what you think.
Big version: Width: 1024 Height: 768 File size: 522kb
EK20
Wed Apr 25, 2007 3:29 pm
The fuselage looks completely washed out. You're not gonna get that on anet I'm afraid.
