mx330
Appealing, Is It Even Useful?
Thu May 03, 2007 7:41 am
Hello, everybody out there.
I would like some clear explanation from the screeners, head if possible about the next following rejections.
This all 3 images were rejected by level (the Mexicana 319 had a badInfo rejection also in which its case I can’t complain…)
I found the 3 shots were perfectly aligned and decided to appeal.
A couple of hour later the images were re-rejected for the same reason.
I do have to accept this time it really frustrated me. Here are the 3 images showing clearly how they are perfectly leveled.
Is appealing really a good idea? For some reason I get the feeling HS don’t even read the comments you put when you appeal. If so, why were these shots re-rejected?
Now not only I’m loosing -12% rate of acceptance instead of getting +6% but actually will have to wait 10+ days in the queue to get them another try.
I’d really hope screeners have a time to clarify this situation.
Thanks in advance.
Juan APM
P.S. I’m still waiting for an answer on the e-mail I send you today, thanks
[Edited 2007-05-03 00:42:47]
All Canon! EOS 5D mk III, 8mm, 17-40, 24-105, 70-200 f2.8, 100-400L
AC773
RE: Appealing, Is It Even Useful?
Thu May 03, 2007 8:06 am
Quoting Mx330 (Thread starter):
I think this is a good example of why comments should be standard practice for appealed shots. If somebody appeals a shot, they clearly don't see an obvious reason why it was rejected.
I myself submitted a shot a while ago that was rejected for motiv. Appealed and same thing. I even started a thread on it appealing to screeners in the title. Plenty of responses, but none from any screeners. After PM'ing Clickhappy, he posted, but he wasn't the one who screened it so his effort didn't help much. With no other responses from screeners, I gave up.
Anyway, I hope your case gets sorted out, and again, I think comments for appealed photos would be a good idea for the future.
Better to be nouveau than never to have been riche at all.
clickhappy
Thu May 03, 2007 12:56 pm
If you appeal a shot, and dont explain why, it goes right back in the trash.
No comment = no appeal.
Your shots are unlevel. Sorry, but they are. I am too tired to draw lines. There is alsio some heat haze.
Royal
mx330
Thu May 03, 2007 2:02 pm
I did explain all of them.
Can you tell me how are they unleveled? I can't seem to see it.
N405MX
Thu May 03, 2007 3:14 pm
On the second one, I think it has to do that the plane is located on a "curve" or turn, maybe that´s why, got the same problem with an A320 in CUL, also rejected by "Level".
Just a posibility.
Saludos
Life is what happens when you have other plans.....
eadster
Thu May 03, 2007 3:21 pm
I'd be aligning the the A320 off the runway, not the ILS tower.
The 747 looks ok to me...
The one with the hangar in background does look weird not being level with the runway...
AMSA
Thu May 03, 2007 9:18 pm
At the first sight I thought they weren't unleveled, but looking carefully I realized that the Mexicana is a bit inclined to the left, needing a few of CW rotation.
On the Lufthansa the light posts on the left are inclined to the left also, as you can clearly see, so I think this one need a CW rotation too.
About the Avolar, I can't figure out the unlevel issue.
Just my 2cents!
Allen A.  wave
Best regards from LIS, Allen Azevedo
LIPH
Thu May 03, 2007 9:49 pm
Juan,
apart from heat haze that Royal mentions :
- First shot looks to be levelled to me...
- Second one I would give some CCW rotation (ILS antenna is clearly unlevelled).
- Third shot I would give abit of CW rotation (look at the light poles behind the back part of the 747 fuselage)
One suggestion I must give you : don't trust the lines you draw with PS or look alike softwares. Once you have decide the vertical (it must be vertical, not horizontal) reference trust your eyes...Probably screeners are more prone to judge by "feeling" rather than having a cristal-clear reference...
Would love to make their screen the PISA tower soon or late...
Ciao
PS
Oh, by the way : no, IMHO, appealing is unuseful. Would love to see the percentage of appealed shots that at the end went into the db...Probably very, very, very few.
[Edited 2007-05-03 14:52:02]
Life sucks. Then you die. Live fast, die young.
clickhappy
Thu May 03, 2007 10:03 pm
As it should be. That means the screeners are doing a good job and the Head Screeners don't have to fix our mistake.
LIPH
Thu May 03, 2007 10:40 pm
Quoting Clickhappy (Reply 8):
Yes, Royal, for this reason I believe that appealing is a loss of time....
Ciao
clickhappy
Thu May 03, 2007 10:56 pm
You have a very negative outlook if you think it is a waste of time. What kind of team would we have if the head screeners overturned the decisions of the individual screeners?
Think about it.
Lanas
Thu May 03, 2007 11:07 pm
Hola Juan
First of all, try to appeal when you´re 100% sure that your shot deserves to be accepted. I´d have posted the photos here before appealing.  duck
Then, regarding the pics, I see they are all clearly unlevel. On the MX shot, the antenna behind the A320 that can be seen between the engines of the Jumbo is unlevel. That´s a vertical reference that is leaning to the right, so you must correct it.
On the Avolar shot, the hangar looks unlevel (vertical lines leaning to the left).
I find the LH shot level, and with no valid reference to look at. The light poles in the left are leaning to the left and the one in the right is leaning to the right. It´s a tricky one. I would have leveled by taking the right light pole as a reference.
Hope it helps.  bigthumbsup
Cheers!  wave
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
LIPH
Thu May 03, 2007 11:30 pm
Quoting Clickhappy (Reply 10):
Royal,
I just want to say that screeners are today very well trained. So there is usually no reason for appealing a shot...The screening process consists of 3 poeple looking at your shot right ? I believe it is more than enough...
I don't know, but maybe you could tell us really which is the percentage of appealed shots that are included in the database at the end...Don't think it is a a big number...Most of the time maybe for motive reasons...(if these ones are not left to Joan)
Ciao
johndm1957
Fri May 04, 2007 1:09 am
I've had a few appeals accepted, but only on 'Double' rejections where I believe its just the first screener has seen two pics of the same aircraft, same day but opposite sides, and just thought they were the same view when initially screening them.
99.99% of other rejections are correct when you really look at your rejection reason. Most decent pictures with minor flaws seem to be rejected with a reason AND 'Personal' with advice anyway.
Just my  twocents
Canon 550D, 18-55, 50 1.8, 100-400L
N405MX
Fri May 04, 2007 2:25 am
Quoting Lanas (Reply 11):
About the sugestions, I also want to know, because I had some level rejections, the problem is, what will be a good reference, instead of an antenna or something in first plain, will be something in second or even third ?
When the hangars are in the background I think it´s even harder to level the shot, or the plane that is in first plain, because the hangars not always have flat horizontal roofs, so if I want to take that as a reference, my plane will be completely out of level -I think-.
So what will be the sugestion for the reference to be taken ?
Saludos
Lanas
Fri May 04, 2007 3:00 am
You should always take vertical lines as a reference, since horizontal lines in most of the cases are subject to perspective and might give you a wrong impression.
Quoting N405MX (Reply 14):
With "In first/second plain" I believe you mean "foreground" and "background", am I right? Big grin
I don´t think that the distance to the reference matters. If it is a control tower it will be very distant but a very valid vertical reference. An ILS antenna by the side of the aircraft will be very close to you and also work as a valid reference.
I hope I could answer your question.  Smile
Cheers!
Lanas.-
Psych
Fri May 04, 2007 6:10 am
Juan - some months ago I kicked up a fuss about this, as I believed that losing a further 2% when a shot was rejected at appeal was unfair. Equally, I felt it was appropriate that when an appeal was successful then the initial loss of 2% should be rectified.
In fairness to Johan, he listened to my comments and adjusted the system. Thus, even though 3 shots were rejected initially and then at appeal, you should still only lose the 6%.
All the best.
Paul
DeltaAVL
Fri May 04, 2007 7:11 am
Quoting LIPH (Reply 9):
I don't think so... I've gotten one that was originally rejected for motive accepted through the appeal queue.
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
MidEx216
Fri May 04, 2007 1:05 pm
Whether or not they read the comments we put on, I don't know. But one of my pictures got rejected, (I can't remember the reasons) but I didn't see the justification, so I appealed, and it got in very quickly thereafter. So, it does work.
Chukcha
Fri May 04, 2007 1:16 pm
Quoting Eadster (Reply 5):
Martin, runways can be sloped, or they can appear that way if the direction of the camera is not perpendicular to the direction of the runway, especially if the photo is taken from an elevated position.
The only thing to rely upon in that shot would be the verticals on the hangar - the construction people do make damn sure they point straight down. Frankly, I don't see what else could be used for reference in this picture, that would be more reliable.
Andrei
N405MX
Sat May 05, 2007 1:31 am
Quoting Lanas (Reply 15):
Right  biggrin  Meaning "Primer Plano, Segundo Plano, Fondo", etc.
Thank you so much, but also add:
Quoting Chukcha (Reply 19):
That´s why I mean, the runway is not straig, for example in MTY we have a slope of 3°, taxiway B has a slope of 5.6°, so getting it leveled or aligned with another thing will be very difficult, also in MEX the mountains in the background make things kinda harder, for example this shot:
MyAviation.net photo:
Photo © Logan Sanchez Ontiveros
I always got the "level" rejection -despite quality, oversharp, and some others in various uploads- what can I take as a valid reference to level the shot ? I tried with the subway in the background, then the subject -the terminal building-, then the hangars in the background, but always level  Sad
Saludos
Lanas
Sat May 05, 2007 2:08 am
Logan,
Quoting N405MX (Reply 20):
The yellow light poles and the columns on the construction site can be used as leveling references.
As Andrei says, vertical lines will always be vertical because 'the construction people do make damn sure they point straight down'. Big grin
Cheers!
Lanas.-
N405MX
Sat May 05, 2007 3:00 am
Quoting Lanas (Reply 21):
The one in the upper of the left wing of the T7 looks leveled, but not the "grid" on the construction, does it has to do because of the perspective ?
I agree, but I´ll try to post some pics of those darn things to show that sometimes in our airports that doesn´t apply at all.........
Thanks for the tip.
Saludos
mx330
Sat May 05, 2007 3:42 am
Thanks to all for your answers.
I will correct the pictures, though most agree LH is straight.
Just off the records, in a place like Mexico city, all posts are inclined differently...
Kudos
Juan APM
eadster
Sat May 05, 2007 9:12 am
Don't take it so seriously. The acceptance ratio should be hidden from some photographers and only accessible by the crew. All its done since being introduced is cause concern. It's taking the fun out of this hobby for some.
Just pretend its not there. Lower percentage does not mean you are bad at taking photos.
Chukcha
Sat May 05, 2007 9:24 am
Quoting Mx330 (Reply 23):
Posts are not very reliable; when I wrote about 'verticals', I meant those in buildings. As for posts, I was editing a picture from an airshow yesterday; there were two flag poles in it, but they were of no use because of the strong wind  Smile ...
Andrei
N405MX
Sat May 05, 2007 2:55 pm
Quoting Chukcha (Reply 25):
Being an earthquake zone, it´s very dificult to get some poles or posts "straight", also for the record, MEX/MMMX is sinking, the airport sanked 40cm in the last 3 years.
Saludos
