adama
Need Help With Rejection (Dirty)
Thu May 03, 2007 5:43 pm
hello to all, i'm new at airliners.net. I'm viewing for a few years your very nice photos, and now i decide
it's time to join this community.
Therefore i was starting with my uploads with 2 photos, one was accepted but the second was rejected, because this phote has blemishes.
I'm ready to learn from my mistakes, but i don't see any dust spots. Maybe someone can mark the critical parts of this image, so i can make it better next time.
Sorry for my bad english  ashamed
greetings
Adama
monteycarlos
RE: Need Help With Rejection (Dirty)
Thu May 03, 2007 5:50 pm
http://img143.imageshack.us/img143/2600/20070503img5380dnz4.jpg
An equalized version of your image with where I see the dust spots...
Seems something weird going on with the tale but I guess it looks ok un-equalized.
It's a beautiful night to fly like a phoenix...
adama
Thu May 03, 2007 6:07 pm
thank you for your fast help, now i can see the problem.
adama
monteycarlos
Thu May 03, 2007 6:22 pm
Quoting Adama (Reply 2):
Bitte.  Wink
its a good technique to keep in mind though. In PS create a duplicate layer, go to adjustments and equalize and it will show up all the dust spots in the image. Correct as required.
Lanas
Thu May 03, 2007 11:14 pm
Hallo Adama!  wave
Quoting Monteycarlos (Reply 3):
Indeed, that works very fine. I have another way of spotting blemishes that might be helpful. That is by using the Levels graph (you can first use the duplicate layer function as Carl said). Press Ctrl+L and the graph will pop up. Then you can set a value between 100 and 130 on the first space of ´Input levels´ (or press Alt+I and type the numbers, that´s if you don´t want to use the mouse). The whole image will darken and will show the dirt clearly. Then when you have spotted the problem you can correct on the underneath layer.  yes
Hope it helps.  Smile
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
adama
Thu May 03, 2007 11:52 pm
thank you all around the World  thumbsup  for your very useful Tips.
Greetings from Germany
Adama
