VICE911
Rejected For Motive. But I Really Like It.
Tue May 08, 2007 5:02 am
This was rejected for motive, but i really like it myself, should i appeal or just leave it. thanks! Yuan Le
http://www.airliners.net/addphotos/rejections/big/20070507_ok-swv3.jpg
Back in China now. Camera used: Nikon D70 D50 D200 D40 FUJI S3 PRO Canon 400D. Now with Nikon D7000.
ANITIX87
RE: Rejected For Motive. But I Really Like It.
Tue May 08, 2007 5:09 am
I see two problems with this image.
Firstly, the crop is a little off. You need to add more space above the plane so that the top of the fuselage is in the picture.
Also, your picture is too tall. Your image is 1024x780, and the rules on airliners.net say it must be between 683 and 768 pixels tall (between a 3:2 and a 4:3 aspect ratio) if it is 1024 pixels wide.
So I would add space above the aircraft and add a little more of the fuselage into the image.
Otherwise, great shot.
TIS
boeingfreak
Tue May 08, 2007 5:16 am
Quoting ANITIX87 (Reply 1):
 checkmark   checkmark
You cut right through the first passenger window and the 'm' of 'SmartWings' + my eyes quickly moved to the pilot...
If you sum it up it is a correct rejection that doesn't need to be appealed.
Florian
waketurbulence
Tue May 08, 2007 5:27 am
1024X780 is ok with the A.net bar at the bottom which is 12 pixels wide. 780 - 12 = 768
I do agree that the crop is off however.
-Matt
LIPH
Tue May 08, 2007 6:42 am
Yuan,
yes, as everybody said before it's just a matter of crop. Quality is there. Re-edit and upload. Very nice shot.
Ciao
Life sucks. Then you die. Live fast, die young.
waketurbulence
Tue May 08, 2007 6:51 am
I also forgot to mention the pilot. Don't write any comments about the pilot giving the peace sign. That would lead to a motive rejection as well.
-Matt
VICE911
Tue May 08, 2007 7:12 am
thanks guys! will try to edit it again, and about the peace will remember that. Ciao! Yuan Le
