Alibo5NGN
Info Reject. Advice Needed.
Tue May 08, 2007 10:47 pm
This shot was rejected for info.
http://www.airliners.net/procphotos/...vlG-MEDKBritishAirwaysTailsLHR.jpg
I used the registration of the 3rd aircraft, G-MEDK in the info I provided when uploading this shot because it is clearly visible and verifiable. The first two aircraft G-MEDM and G-MEDF do not have visible registrations except two letters on their rudder. All other info pertaining to this shot including Airport and date are accurate. Is there a rule on Anet as to which registration we have to use in a shot containing several planes? Your help will also be appreciated If I have omitted any other info.
Ken.
It takes knowledge to make a career. It takes wisdom to live a life.
Fly747
RE: Info Reject. Advice Needed.
Tue May 08, 2007 11:00 pm
I believe it should be the plane closest to you. It could also be verified because it has the last 2 letters on the tail.
Ivan
Rotate
Tue May 08, 2007 11:02 pm
Quoting Fly747 (Reply 1):
 checkmark   checkmark   checkmark
Robin
ABC
johndm1957
Wed May 09, 2007 12:56 am
The registration of the 3rd aircraft, G-MEDK is the most visable, as is the aircraft as stated in the upload guide....maybe something else was wrong in the info?
Canon 550D, 18-55, 50 1.8, 100-400L
unattendedbag
Wed May 09, 2007 3:27 am
did you click "Tail/Winglet"?
Slower traffic, keep right
Lanas
Wed May 09, 2007 3:37 am
Hi Ken
I would have used the registration of the first aircraft, since it can be easily verified, as Ivan said.
I like the pic very much, but the third aircraft being shown much more than the first ones makes it a bit odd, motive-wise speaking.
Good luck with it.  Smile
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Fly747
Wed May 09, 2007 4:46 am
Quoting UnattendedBag (Reply 4):
That would have been a "category" rejection.
Ivan
Alibo5NGN
Wed May 09, 2007 5:39 am
YES!
Quoting Lanas (Reply 5):
It is a no win situation. Tail category fits this more than Airliner category. This reject for info came from the second or third screener. A shot of mine that was uploaded after this one on a different day was rejected while this one was still in screening. This shot was eventually rejected for info about 12 hours later.
