AviatorG
Does This Fit The 'dark' Category?
Sat May 12, 2007 4:40 am
Hey friends wave
Recently I had a few 'category' rejections for photos (taken at dusk) which I had uploaded with the 'dark' category option selected. I hope I can soon recognize how dark is dark enough for that category to be selected, since I don't want to bring my acceptance ratio down further for that reason crying . Can someone kindly advise on whether the below photo (link) should be put into the 'dark' group?
http://www.airliners.net/addphotos/b...ady/Frenchwest_Landing_Edited3.jpg
Rejection example tombstone  : http://www.airliners.net/addphotos/r.../20070422_AJM_GND_100407_Edit7.jpg
(also 'soft')
Best regards, & thanks in advance
cool
Newark777
RE: Does This Fit The 'dark' Category?
Sat May 12, 2007 5:07 am
I don't know about dark, but it looks blurry and over sharpened as well.
Harry
EK20
Sat May 12, 2007 5:08 am
Quoting AviatorG (Thread starter):
Lovely shot but I think it will get booted for being blurred. That's the first thing I noticed around the reg and rear door.
Boston92
Sat May 12, 2007 5:11 am
I honestly think the "rejected" one would have a better chance of getting accepted... but they are not bad shots, just not up to par.
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
AviatorG
Sat May 12, 2007 5:47 am
Thanks again for the comments. Pulled it from the que  Smile
acontador
Sat May 12, 2007 5:48 am
Hi Gianni,
First to your original question: Both pictures do not fit into the DARK category. While I also have from time to time my doubts with borderline cases, your pictures are clearly taken in the evening SUN...the sunlight is clearly visible. When the sun is very low, or even starting to disappear behind the horizon (whatever 'horizon' you have on each location), then you should start to think about this category. But as long as you have direct sunlight as in your pictures, you should not select this category.
I think the ATR 72 is very slightly blurry, and the light direction+background makes this a high contrast one, which will make the jaggies much more apparent.
The Air Jamaica could use a different editing process, with more 'general' sharpening before the selective sharpening part. This one should make it in.
Just sit back, relax and have a glass of Merlot...enjoy your life!
