f4phantom
Number Of Actuations On Canon Bodies
Sun May 13, 2007 2:51 am
I use both the Canon 300D and 30D camera bodies. Sometimes i notice photographers on here state how many actuations a camera has taken, often quoting numbers in the thousands. Am wondering how it is possible to access this information, is it held in the data within the camera? Thankyou.
KMB
RE: Number Of Actuations On Canon Bodies
Sun May 13, 2007 2:56 am
The number of actuations are recorded on the memory card but this is unreliable since if you change the card the number will vary. Canon are able to read the exact number of actuations and this information is usually provided if your camera is serviced.
Kevin
Better to ask a stupid question than make a stupid mistake.
f4phantom
Sun May 13, 2007 5:11 am
thankyou, appreciate your input
SFO2SVO
Sun May 13, 2007 6:48 am
Exif viewer here: http://homepage.mac.com/aozer/EV/
extracts this info from EXIF data, just check any of the pics taken with your camera. At least for Nikon
I am not sure if it will support Canon and it runs on Mac - but there are plenty similar utilities for PC out there.
318-19-20-21 332 343 717 727 737-234578 743-4 752 763 772 D9/10 M11/8x/90 F70 RJ85 ATR72 SF340 E120 TU34/54 IL18/62/86/9
walter2222
Sun May 13, 2007 7:13 am
Quoting SFO2SVO (Reply 3):
I believe the exact count of the actuations is only stored in the EXIF-file by the 1D models, not by the other models...
PS: I use a 300D and I have checked with an Exif-reader: there is nothing at these file-locations...
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
INNflight
Sun May 13, 2007 7:33 am
Quoting Walter2222 (Reply 4):
With the 300D, you can choose to either reset the "counter" (=file names) every time you use a new, empty memory card, or continuously number the files.
E.g., CRW_8644 is the 8644th actuation, however the 300D counter automatically starts at zero after CRW_9999 I think.
Jet Visuals
walter2222
Sun May 13, 2007 8:07 am
Quoting INNflight (Reply 5):
That's correct, Florian!
But that's only related to the file-numbering on the CF-card.
It seems, however, if you mix CF-cards with an existing file-numbering, without reformatting in other camera's and than back, the numbering system is not reliable anymore... (I haven't tried it myself, but it was a topic under discussion on the "scramble"-forum some weeks ago).
Walter
monteycarlos
Sun May 13, 2007 8:37 am
How mand actuations do Canon state you should get out of a 30D or 300D?
It's a beautiful night to fly like a phoenix...
KMB
Sun May 13, 2007 3:44 pm
A friend of mine recently purchased a secondhand 30D and the shutter button failed. When it came back from repair they had not only replaced the shutter button but the complete shutter assembly with a note to say it had completed 66,000 shutter actuations.
cheers
Kevin
KMB
Sun May 13, 2007 3:57 pm
Quoting Monteycarlos (Reply 7):
I seem to recall reading the figure was 50,000 for a 300D and 100,000 for the 30D but I have also seen a figure of 200,000 for a 30D. You will know when it fails  Wink
Kevin
monteycarlos
Sun May 13, 2007 4:12 pm
Quoting KMB (Reply 9):
 Smile I guess I will. I guess this is not something covered under an extended warranty either?
KMB
Sun May 13, 2007 4:15 pm
Quoting Monteycarlos (Reply 10):
It depends on who your warranty is with but in most cases I would expect it would be covered.
monteycarlos
Sun May 13, 2007 4:16 pm
Quoting KMB (Reply 11):
Ah good. Thats a relief. Although by then I'll probably have a 5D.  Smile
KMB
Sun May 13, 2007 4:21 pm
Quoting Monteycarlos (Reply 12):
With Canon cameras our biggest problem is DUST on the sensor, especially if you have the Dyson pump 100-400 lens. Sad
walter2222
Sun May 13, 2007 8:38 pm
Quoting KMB (Reply 13):
It is a little bit off-topic, but I would not blame the lens... it is more about changing the lenses in an environment which is often not so clean...
Walter
jrowson
Sun May 13, 2007 9:44 pm
My 20D came back from service last year with the total number of actuations written down, so I guess that service engineers can get access to this info. I wonder if the end user can access it somehow?
James Rowson
KMB
Sun May 13, 2007 11:48 pm
Quoting JRowson (Reply 15):
Canon only release this information to their service agents but they all appear to use it when a camera goes in for repair.
f4phantom
Mon May 14, 2007 12:35 am
interesting input, thanks. Just curious as to how many images i have taken over the years. wouldnt even like to hazard a guess.
KMB
Mon May 14, 2007 12:38 am
Quoting F4phantom (Reply 17):
Trust me it's best not to know  Wink
jorge1812
Mon May 14, 2007 5:16 am
Anyone tried out on Windows with a Canon?
georg
Users browsing this forum: Virginblue4 and 1 guest
