cloudboygee
Nikon 70-200VR + 1.7x
Wed May 16, 2007 8:28 am
Hi There
I wasnt so happy with the 80-400VR I took to the Avalon Airshow... I found it ti be abit 'soft' at full extension, and very slow on the autofucus. But the focal length was lovely...
Would a combination of Nikon 70-200 f.2.8 VR + 1.7x converter be better than an 80- 400?
Does any body here use this combination?
Is there anything else other than the 200-400 which is way out of my reach?
Chris Gee
Boom Shanka
CalgaryBill
RE: Nikon 70-200VR + 1.7x
Wed May 16, 2007 8:46 am
I use that combination and it works pretty well. FWIW, when I bought the 70-200 I did some unscientific comparisons of the 70-200 + 1.7 vs the 80-400 (handheld, in-store). I found the 70-200 was comparable, if not slightly sharper than the 80-400. Of course, focusing was still faster than the 80-400, and if you go with the combination of lens/TC, you get an unbeatable lens when not using the TC.
If you don't want to spend that much money, take a look at the 70-300 AFS VR that just came out. It doesn't have the wide aperature of the 70-200, but the quality is pretty good, especially for the price. Or, keep saving your pennies for the 200-400, it's worth it!
B
billsville
Wed May 16, 2007 9:45 am
I use that exact combo and have no problems with it at all. Focus is quick and you don't loose too much of the sharpness that the 70-200 has. Even opening it wide up to do some night shots handheld using the VR it still holds up well. It's better range is to keep it up around f8, especially if your going to be zoomed right out a lot. But still a good combination.
cloudboygee
Wed May 16, 2007 11:44 am
Thanks for that  Smile How much slower will the 2x converter make it? or Do you think I should stick to the 1.7?
Boom Shanka
billsville
Wed May 16, 2007 12:59 pm
I also have the 2x and unless its an extreme situation i don't use it. You really need good light and keep it up over F8 to get good shots. It does diminish the sharpness a lot more than the 1.7x, I was surprised when I tested the two out.
Photo © Stephen Brown
The one on the left is with the 2x, the right the 1.7.
If you don't need that bit extra, stick with the 1.7x. Also if you have a 8-10Mp camera you can crop a little more then as well.
BO__einG
Wed May 16, 2007 1:04 pm
I use that combo too, works excellent IMO.
It takes a bit of trial and error to get the best settings and focuses to set so the shots will come out the sharpness and quailty that you want.
Only compromise is that you won't get the reach as the 80-400 as this combo takes you to 340mm. Then again add the 1.6 or so and it is like.. alot, 510mm or something like that.
Good as it gets for handheld  Smile
Follow @kimbo_snaps on Instagram or bokimon- on Flickr to see more pics of me and my travels.
unattendedbag
Wed May 16, 2007 1:39 pm
Quoting Billsville (Reply 4):
Both are Kick Ass shots. What body are you using?
Slower traffic, keep right
viv
Wed May 16, 2007 3:07 pm
Nion recommend that teleconverters be used only wth prime lenses, not with zooms.
CalgaryBill
Wed May 16, 2007 3:45 pm
Quoting Viv (Reply 7):
Maybe as a rule of thumb, but Nikon engineered the second generation (the II's) specifically to work with most of their AF-S, fixed-aperature zooms. More important to remember is that TC's exacerbate any flaws in the lens, so better quality lenses will suffer less with a TC. I'd put the 70-200 AFS VR F2.8 with TC 1.7 II up against most of Nikkor's older primes.
From Nikon's website (the TC 1.7 II page):
"Compatible with AF-S and AF-I Nikkor lenses except AF-S 17-35mm f/2.8D IF-ED, 24-85mm f/3.5-4.5G IF-ED, VR 24-120mm f/3.5-5.6G IF-ED, 28-70mm f/2.8D IF-ED and DX Nikkor lenses."
B
beechcraft
Wed May 16, 2007 4:56 pm
Hi,
i hardly used my 70-200 with the 2x TC, as Billsville said before, i als was a lot happier with the 1.7x TC.
However everything was stolen shortly i got the 1.7 so i don´t have any good photos for you to compare.
Meanwhile i got a refurbished 200-400 at Adorama, which was basically brand new, but came with a 500$ discount.
There simply are no suitable words for this lens....  cloudnine
However, i´d recommend the 1,7x TC over the 2x.
Denis
That's it! You people have stood in my way long enough. I'm going to clown college!
billsville
Wed May 16, 2007 6:19 pm
Quoting UnattendedBag (Reply 6):
D200...Love that camera.....
And I'd llove to get a 200-400mm...Some say its as good as a Prime.....
The 300mf2.8 would be good to have as well...Somebody give me some cash
[Edited 2007-05-16 11:24:52]
IngemarE
Wed May 16, 2007 9:56 pm
Quoting CloudBoyGee (Thread starter):
I use a Sigma 120-300 2,8EX HSM and it's really sharp with the Sigma 1,4EX extender. No optical stabilization though, so you must get a drink or two first  bigthumbsup , especially if you plan on using the Sigma 2X EX on the lens.
It does produce really good results even with the 2X extender on, but as I mentioned,...you need a steady hand shooting at 600mm. When I do, I use a monopod for it, since it weighs a wee bit more than most glass.  Wink
In thrust I trust.
cloudboygee
Fri May 18, 2007 10:33 am
After correspondance here and else where, it is clear to me that the extra reach of the 2x converter is not worth the loss in f-stops and slowing of the autofocus... So its 70-200 VR + 1.7x for me!
Boom Shanka
