walter2222
Would This Be Considered Double?
Sat May 19, 2007 2:43 am
Hi there,
Assuming it would be accepted, would this close-up be considered as a double:
http://walter2219.fotopic.net/p41406014.html
with this one already in the database:
Photo © Walter Van Bel
No need to click on the thumb, I just want to know whether a close-up (almost similar angle) would result in a double-reject.
PS: Since most of my close-ups have been rejected in the past, comments on the crop of the close-up are also welcome!
Thanks and regards,
Walter
[Edited 2007-05-18 19:45:41]
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
clickhappy
RE: Would This Be Considered Double?
Sat May 19, 2007 2:53 am
Yes, would be rejected for being a double.
walter2222
Sat May 19, 2007 5:20 am
Thanks, Royal!
That's clear!
Walter
Lanas
Sat May 19, 2007 5:49 am
Walter I hope you don´t mind if I use your thread for a similar question.  cheerful
It´s regarding this pic:
I was wondering if I´m allowed to submit the photo in question, since there´s already picture of the same aircraft, but parked in a nearby position, not taxiing. It´s not the same photo sequence, but it´s the same depicted side of the a/c, so I wanted to know if it would qualify as 'double' or not.  alert
Photo © Gaston Labougle
Thanks! Big grin
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
clickhappy
Sat May 19, 2007 5:51 am
yes would also be a double and rejected
Lanas
Sat May 19, 2007 5:52 am
OK, thanks!  thumbsup
Lanas.-
EK20
Sun May 20, 2007 3:16 pm
Are these not considered doubles? Same photographer, two taken on the same day and one taken the day after, all of the same aircraft.
Photo © James P Matthews
[Edited 2007-05-20 08:16:49]
Stealthz
Sun May 20, 2007 5:08 pm
Quoting EK20 (Reply 6):
I would tend to call the first 2 double as the date and side of aircraft are the same, I also believe the screeners reserve the right to reject multiple similar photos from the same location as "double" even if the dates differ.
Another curious thing about these is that one is listed as RAF and the other 2 as Saudi Arabia, Air Force, whilst I accept that this airframe is 6613 of the RSAF and is in the UK for upgrading it is clearly carrying RAF markings and serials.
walter2222
Sun May 20, 2007 6:51 pm
Quoting StealthZ (Reply 7):
Althoiugh they look similar at first glance, the first one is a landing shot, whereas the second is on take-off (so two different sequences), that is acceptable according the rules. The third one shows the other side of the aircraft, so that is also OK!
Hope this helps.
Walter
topgun3
Sun May 20, 2007 11:00 pm
Just wondering.
I had 3 pictures of same aircraft (a helicopter) in for screening. One was an outside shot, one was an instrument panel and one was a close-up of the tail. Unfortunately none of them got in due to some inconsistent screening criteria....but what really got me hot under the collar was a rejection for "duplicate" when none of the other pictures got in. How can it be "Duplicate" when there is no other picture in the DB?
I'd rather be flying.
Lanas
Mon May 21, 2007 12:24 am
Quoting TopGun3 (Reply 9):
Hi Mark
It would be nice if you posted the shots in question. You´ll get better feedback that way, IMO.
Cheers!  Smile
Lanas.-
TedTAce
Mon May 21, 2007 12:37 am
This has me curious. I have two in the que of the same A/C(not currently in the DB) on the same day. But they were both on two seperate approaches. One picture taken from head on has the A/c comming directly at me, the other one focuses on the front part of the Aircraft but notably from the side. Thoughts? My opinion and train of thought was that it's two VERY clearly different views of the A/C and definatley two seperate approaches so not exactly the same time.
This space intentionally left blank
acontador
Mon May 21, 2007 1:00 am
Hi Ted,
Post them to have a look, but I can tell you I have had my fare share of doubles if they are same day and same side, whatever the aircraft are actually doing - to have them accepted it must be different sides.
Just sit back, relax and have a glass of Merlot...enjoy your life!
walter2222
Mon May 21, 2007 3:38 am
Quoting TedTAce (Reply 11):
Thoughts?
This is mentioned in Thierry's document (IGRR):
A small note concerning sequences: you may distinguish 3 different sequences: landing, on the ground (taxiing) and take-off; as a 4th sequence you might add fly-pasts but apart from airshows you'll rarely have one of those. According A.net rules you may only upload ONE photo from each given sequence and rarely you'll get more then 2 shots from the same a/c at the same airport and date accepted even if they are all from different sequences. For the "on the ground" sequence you might get 2 photos of this sequence accepted if they show really different motives like a close taxi by and some interesting (un-)loading action.
and for completeness, the link:
http://planecatcher.com/IGRR2.htm
PS: What I also learned - from inputs from Royal - is that a close-up (from a similar angle/side, during the same sequence) and a standard shot will also be classified as double.
Walter
topgun3
Mon May 21, 2007 6:59 am
Quoting Lanas (Reply 10):
Hi Mark
Here are the links to the rejected photos.
http://www.airliners.net/addphotos/r...ctions/big/20070520_DSC09333b2.jpg
http://www.airliners.net/addphotos/r...ctions/big/20070520_DSC09335c1.jpg
http://www.airliners.net/addphotos/r...ctions/big/20070520_DSC09362b2.jpg
acontador
Mon May 21, 2007 7:24 am
Hi Mark,
Well, it would have been even more helpful if you could have posted the full rejection reasons for each one, along with the order in which they were rejected.
I suspect that none got in is the end-result of the screening. Let's put it this way: If I was looking at your pics for the first time as a screener, I would have also rejected either the full side-on or the tail right away for double, as they show same side/same day/same rego/same photog. Then, maybe even another screener might have found a different fault in the other picture, thus reject it at a later stage of the screening process. You see, at least a reasonable explanation, so no need to get
[Edited 2007-05-21 00:26:46]
TedTAce
Mon May 21, 2007 9:37 am
Quoting Acontador (Reply 12):
This re-assures me as the perspectives are definately different, and definately on seperate passes (either that or I'm in a lot better shape then I thought).
