walter2222
Would This Be Acceptable?
Sat May 19, 2007 8:15 am
Hi there,
I have scanned some slides from RIAT 1995 and found some cockpit shots of the Slovak Air Force Mig-29UB.
http://walter2219.fotopic.net/p41414407.html
http://walter2219.fotopic.net/p41414411.html
http://walter2219.fotopic.net/p41414408.html
I would like to know whether such shots would get a motiv reject (a kind of wire/cable obstructing the view?) or is quality of the scans too low (1995 period)? Any other comments?
... and would this one get a motiv rejection for the stairs in front of it (although there is only 1 other shot of this aircraft in the database)?
http://walter2219.fotopic.net/p41414966.html
Walter
[Edited 2007-05-19 01:46:06]
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
Lanas
RE: Would This Be Acceptable?
Sat May 19, 2007 11:31 pm
Hi Walter  wave
I believe the three first would be facing a motive rejection, specially the last two within these. The first one is better but I believe that if you cut a bit on the sides, focusing only in the panel and the windscreen, it would be more appealing. However, the shot is soft and has some colour cast (might say a bit reddish, IMO).
The fourth shot will be killed by motive because of the stairs, I guess. It´s also a bit too dark.
Hope it helps. Big grin
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
walter2222
Sun May 20, 2007 7:48 am
Quoting Lanas (Reply 1):
Hope it helps.
Thanks, Gaston!
Every feedback is appreciated! I will try a tighter crop on the first one, but as you also thought, there is the possibility for motiv-reject... But, no problem, I like them also in my personal website  Smile
PS: my slides were also on the dark side, and while trying to lighten them in PS, they become too grainy...
Thanks and regards,
Walter
Users browsing this forum: aussie18 and 1 guest
