FXfan
Ball Head Question
Tue May 22, 2007 4:59 pm
I need some advice on finding a tripod and head to support a 30D with a 70-200 2.8 IS with no problem.
fergulmcc
RE: Ball Head Question
Tue May 22, 2007 5:40 pm
Have a look at the Manfrotto MN 488RC4 Ball head. It can take a good load. Well able to support my 500/4 and 1Dn
http://www.mifsuds.com/acatalog/Manfrotto_Heads.html
It has a detachable plate and you can get some spare plates as well, MN 410 PL http://www.mifsuds.com/acatalog/Manfrotto_Plates.html . The plates even have two threaded holes so the you can attach a monopod with out having to removing the plate. Its a very smooth ball with a pan facility and won't cost you the earth.
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
INNflight
Tue May 22, 2007 7:38 pm
Quoting Fergulmcc (Reply 1):
Can support Fergul's suggestion, I use it for about half a year now and love it to bits!
Well spent money!
Florian
Jet Visuals
CalgaryBill
Tue May 22, 2007 9:08 pm
I've got the 488RC2 and it's also a great little head. The plate on it is smaller and works with several other of Manfrotto's heads.
B
FXfan
Wed May 23, 2007 6:27 am
Whats the difference between the 2 and the 4?
CalgaryBill
Wed May 23, 2007 10:47 am
Quoting FXfan (Reply 4):
The 2 just has a smaller release plate. I keep a plate on my camera, my 70-200 and 200-400 (plus a spare in a pouch attached to the tripod, in case I remove and forget the others!), so the smaller the better as far as weight and space go. But the larger plate may offer more stability. As far as I can tell, the two heads use the same mechanism, so mechanical strength should be similar.
B
AC773
Wed May 23, 2007 12:15 pm
Quoting CalgaryBill (Reply 3):
 checkmark  I've got this on a set of Manfrotto 3021 Pro legs - I can't say enough about this combo. It's SOLID!!
Saw some guy the other day videotaping a theater performance at my college. He was using a ~2 grand Sony video camera mounted on an $80 tripod from Best Buy. It even said "7500 Pro" on the side of it! I had a good laugh in the next room.  biggrin
Better to be nouveau than never to have been riche at all.
DC3
Thu May 24, 2007 6:47 pm
Depending on how much money you want to spend, you might have a look at the Really Right Stuff (RRS) ballhead. I've use several different makes over the years, including Manfrotto, Gitzo and Arca-Swiss and, so far, the RRS model is the best. (Not because I collect gear, you understand, simply because I've used the others to destruction before moving on!)
Chris
fergulmcc
Thu May 24, 2007 7:02 pm
It pays to buy quality, and if that means forking out a bit more cash then so be it. I have had my experience with cheap tripods and ball heads, and it's just not worth the hassel. I remember once when I was taking some shots of a stream and I was cold and wet, I slipped and fell, trying to get into a position for a shot that I saw, on my cheap tripod and two of the legs broke. Trust me I could have launched that tripod to Mars and beyond!
Take care
Fergul  sun
DC3
Fri May 25, 2007 5:00 am
Yep, a tripod with two broken legs is of limited use.  Wink
I once dropped a 90mm tilt and shift lens into the River Dove in Derbyshire. This was not a happy day for me.
Chris
aviopic
Fri May 25, 2007 5:36 am
Currently I am using a 486RC2 which does ok upto 400mm.
As a replacement I am seriously looking at a Gimble action head which especially works great for moving objects.
For example: http://www.riestripod.com/dpnp.htm
The price is a bit hefty though.
The truth lives in one’s mind, it doesn’t really exist
fergulmcc
Fri May 25, 2007 6:13 am
Quoting Aviopic (Reply 10):
Similar to this one too, but a bit more expensive,
http://www.warehouseexpress.com/?/photo/tripods/wimberley.html
Fergul  sun
aviopic
Fri May 25, 2007 6:25 am
Quoting Fergulmcc (Reply 11):
It looks to be a little bit less versatile with only one way to mount the cam.
With the other you can rotate the tripod mount so it fits on the bottom, side or even on top.
I've seen somebody(a pretty well known somebody) working like this at Duxford with the camera hanging down inside the gimble, it was perfectly stable even with hands off.
For this price though I better make one myself, I am sure I have some aircraft aluminum left and 3 bearings shouldn't be a problem either. Big grin
