garry
Canon 500 F4 & 300 F2.8 Drop In Filters
Wed May 23, 2007 8:51 pm
Guys I'm looking for some advice on the drop in filters available on the 500 f4 and 300 2.8 canon lenses.
There is a polariser option (pl-c) which apparently allows for easy adjustment similar to a conventional polariser, has anyone any experience of this and how easy is it to operate?
The drop in holder takes a 52mm screw in nd grad (amongst other things) - how many stops of an nd grad have people used when shooting into very bright light and even solar shots? Again any feedback would be appreciated.
Garry
www.garryridsdale.com
DC3
RE: Canon 500 F4 & 300 F2.8 Drop In Filters
Thu May 24, 2007 6:44 pm
Hello Gary.
The 300 f2.8 I have here takes 48mm drop-in filters (it's the older non-IS version). Anyway, it's the same for all practical purposes and operating the polarising filter is very easy. A small thumb-wheel on the top of the holder allows you to adjust it very precisely. Certainly easier than using a conventional front-of-lens polariser when you are using a lens hood.
No experience of ND filters on this lens but I often use a Cokin two-stop ND for slowing down shutter speed (running water, etc.). According to my information, the only 52mm drop-in filter is the polariser (£189.99!), although there is a 52mm drop holder for gelatin filters - perhaps this is what you had in mind.
Hope this helps,
Chris
fergulmcc
Thu May 24, 2007 7:09 pm
Quoting DC3 (Reply 1):
Thanks Chris!!  bigthumbsup  I have the same gear and have been looking at the drop in filters as well.
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
garry
Fri May 25, 2007 12:41 am
Yes thanks Chris very useful especially the ease of use of the polariser.
Garry
javibi
Sun May 27, 2007 4:02 am
Quoting Garry (Thread starter):
I use ND 64x (6 stops) and 8x (3 stops) in my 500, both to obtain a reasonable f number when panning in full daylight and for some solar shots (not really needed for those during sunset/sunrise, unless you want to get a "very high contrast" effect).
j
Dehowie
Fri Jun 01, 2007 3:38 pm
I have the PL for my 300 and 500 and yes its very easy to use.
Same filter for both.
Drop in and has a small wheel on top of the filter to allow rotation.Easier than a standard PL to use.
Not cheap but you will get good results with it as it is easy to use.
Dazz
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
garry
Fri Jun 01, 2007 9:55 pm
Thanks Darren / Javi - the polariser is on order and I took delivery of the 8x (3 stop) ND this morning. Looking forward to trying it out over the weekend.
Garry
thowman
Sun Jun 03, 2007 12:53 am
Quoting Javibi (Reply 4):
Javibi, how does the auto focus cope when you have such dark NDs in the lens?
javibi
Wed Jun 06, 2007 1:38 am
Quoting Thowman (Reply 7):
With the 64x it does get slower and the the viewfinder is so obscured that you may have trouble finding your subject  Smile
j
Users browsing this forum: river38 and 7 guests
