walter2222
Would This Scan Be Acceptable?
Sat May 26, 2007 10:15 pm
Hi there,
I have scanned a slide from RIAT-Fairford 1995, but the aircraft is low in the frame:
http://www.airliners.net/addphotos/b...9507xx_scan20070518_WVB_1200px.jpg
Would this be allowed for a scan from a slide (there are only 4 other shots of this aircraft - all from the left side - in the database) or not? Any other problems?
Thanks and regards,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
GVerbeeck
RE: Would This Scan Be Acceptable?
Sun May 27, 2007 12:53 am
Hi Walter,
it looks good quality-wise for a scan and we are rather lenient on cropping on older shots. I'd just try to reduce the magenta cast a bit...
Grts,
Giovanni
dendrobatid
Sun May 27, 2007 1:31 am
Wlater
I consider the magenta cast to be unacceptable but it is very correctable. Just add some green until the greys are neutral
Mick Bajcar
walter2222
Sun May 27, 2007 2:03 am
Thanks for the feedback, Giovanni & Mick! Much appreciated (as are the "personals" with the rejects, that is very helpful and is very good advise, now I just have to learn to do it right from the start...)
I will pull it from the queue and rework it!
PS: For some viewers that come in late (after pulling it from the queue), here 's a link to the same shot (but on my personal website):
http://walter2219.fotopic.net/p41612580.html
I have re-edited it (removed the color cast), and this looks indeed better:
http://www.airliners.net/addphotos/b...can20070518_WVB_1200px_re-edit.jpg
Unfortunately, I have noticed that another uploaded shot (which is already in screening for most of the day) has a similar color cast... if it would be accepted as such, I promise to re-upload a better/improved scan  Smile
PS: would this color cast problems be typical to my old slides or is it just old me (and my editing techniques)?
Walter
[Edited 2007-05-26 19:23:17]
dendrobatid
Sun May 27, 2007 2:59 am
Walter
This magenta cast seems typical of old scanned slides, probably due to a fading dye.
It is usually correctable by adding green and sometimes a touch of cyan too (to remove red)
Mick Bajcar
walter2222
Sun May 27, 2007 3:11 am
Quoting Dendrobatid (Reply 4):
Thanks, Mick!
That's again a lesson learned! I was always comparing my edited result with the original slide, I 'll to improve that with future uploads!
Walter
