Longhornmaniac
Some SXM Shots, Any Of Them Worth It?
Thu Jun 14, 2007 11:47 am
Hey guys, I just got back from SXM, and I got some shots that are good by my standards, but I wanted to see if any of them are worth editing, and possibly uploading, with some hope of getting accepted.
Here are the ones I think are my best:
http://i98.photobucket.com/albums/l244/Longhornmaniac8/DSC02132.jpg
http://i98.photobucket.com/albums/l244/Longhornmaniac8/DSC02089.jpg
http://i98.photobucket.com/albums/l244/Longhornmaniac8/DSC02084.jpg
http://i98.photobucket.com/albums/l244/Longhornmaniac8/DSC02019.jpg
http://i98.photobucket.com/albums/l244/Longhornmaniac8/DSC01819.jpg
Is there any hope for ANY of these??? I'm so proud of them, but I honestly have no idea how my camera stack up with the rest.
I appreciate the input/criticism.
Cameron
Cameron
eadster
RE: Some SXM Shots, Any Of Them Worth It?
Thu Jun 14, 2007 5:21 pm
Its hard to tell from the current sizes. We need bigger versions.
fergulmcc
Thu Jun 14, 2007 6:23 pm
Quoting Eadster (Reply 1):
 checkmark
Also crop a lot tighter, far too much space in front and behind the aircraft on all the shots.
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
KaiGywer
Thu Jun 14, 2007 11:07 pm
Motive wise, I think the ATR is the best. Then again, I'm no screener  Smile
jamesjimlb
Thu Jun 14, 2007 11:14 pm
i like it, they look good i could definetly see them in the database if this made it:
Photo © Frank Kuehne
The sky is no longer the limit, but the mere minimum
bmibaby737
Thu Jun 14, 2007 11:46 pm
Quoting JamesJimlb (Reply 4):
Why do you say that?
EZEIZA
Thu Jun 14, 2007 11:49 pm
Personaly I like the KLM best, but it looks maybe slightly off centered? (note: this comment is from someone with only 7 pics in the db so don't bother reading my opinion  Wink )
regards  Smile
Carp aunque ganes o pierdas ...
KLM772ER
Fri Jun 15, 2007 12:23 am
Motivwise I would also say that the ATR is best one...
Quoting EZEIZA (Reply 6):
As mentioned by Cameron these are unedited version, so this should easily be correctable.. But the KLM looks a bit blurry to me from the small picture, so it will probably be hard to safe it....
Thats the problem, it is hard to tell anything at the current size...
But (except the ATR) the all don't really look very appealing..
regards
Björn
Lanas
Fri Jun 15, 2007 1:03 am
Cameron
As the guys said, you need to post the images in the final size, in order to get a more accurate feedback on quality.
In my opinion, they´re not that bad, but they may have some flaws:
- Corsair 747 is overexposed, and I don´t think it can be saved.
- AA 757 is not that bad.
- DL 757 is overexposed pretty badly. The whites are blown out, maybe due to the angle of the sun on the fuselage.
- KL MD-11 looks dark, with the nose and other parts blurry.
- ATR shot seems to be the finest of all. You might need to brighten it up a little.
Hope it helps.  bigthumbsup
Hi! I haven´t seen you in the forum since a while ago. Nice of you to stop by again.  Wink
Cheers  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
EZEIZA
Fri Jun 15, 2007 1:06 am
Quoting Lanas (Reply 8):
Thanx  Wink Como va todo!
I work too much so by the time I have time off I tend to sleep more than sit in front of a computer! Big grin
jamesjimlb
Fri Jun 15, 2007 1:29 am
Quoting BmiBaby737 (Reply 5):
it's pretty bad, it's way to far away.
Longhornmaniac
Fri Jun 15, 2007 2:32 am
Wow guys, I appreciate all the input!
I suppose my question is, what should the final size be? All of those have been resized from 3072 x 2048 down to 800 x 533.
Since I'm new to photography, what is the correct size to make them?
Also, on some of these, I'm not sure which, I have done the Auto Smart Fix (bad idea, I know) in Photoshop Elements (which is currently the only photo editing software I have). I saved them as entirely different copies, for my trip report, so it's possible some of the overexposure could be as a result of that, in which case I still have the original untouched.
Thanks all!!!!! Hopefully we can maybe get at least the ATR saved!
Cameron
Cameron
DeltaAVL
Fri Jun 15, 2007 2:45 am
Quoting JamesJimlb (Reply 10):
It appears to be cropped about as closely as you can crop....
I think it just appears so far away because of the obnoxiously long length of the 753.
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
bmibaby737
Fri Jun 15, 2007 4:20 am
Complete BS!  Yeah sure It's perfectly fine! IMO it's disrespectful of the photographer to use his/her photo(s) and say that they are bad once they've been accepted.
Quoting DeltaAVL (Reply 12):
Esactly!  Smile
Quoting Longhornmaniac (Reply 11):
Try 1024 width, Longhorn! 800 pixels will get rejected
Post it again with the above 1024 size, and I'm sure all of us here can lend a helping hand!
Good Luck!  Smile
Bmibaby737
brianw999
Fri Jun 15, 2007 4:39 am
Quoting BmiBaby737 (Reply 13):
Complete BS! It's perfectly fine! IMO it's disrespectful of the photographer to use his/her photo(s) and say that they are bad once they've been accepted.
I quite agree. Personally, I think its time for admin to hand out some severe wrist slaps to anyone who does this in future. Comments about, and the use of others already accepted pictures to show personal dissatisfaction are plain rude, non-productive and irrelevant to the thread.
...and to get back to the thread....
We definately need to see them at 1024 wide as a minimum.
They all look a bit soft.
Corsair is too high in the frame and needs a tighter crop.
American needs a touch more contrast before sharpening.
Delta is overexposed. I don't think that one can be saved.
KLM is dark and will also need a shot of contrast. Crop a bit tighter.
ATR has the best promise but be careful you don't blow out the whites.
Longhornmaniac
Fri Jun 15, 2007 5:01 am
Ok guys, here are the originals. I know the KLM is WAYYYY too dark, and the one you saw in the previous post was after I Auto Smart Fixed it with Elements. Just a question, for the photos that are too high (or low, for that matter) in the frame, what do you suggest? If I crop off part of the bottom, won't it ruin the 3:2 aspect ratio? In that case, what is best? Thanks for the help guys!
http://farm2.static.flickr.com/1358/548907879_51c4dfc987_o.jpg
http://farm2.static.flickr.com/1065/548907911_c6a65c046a_o.jpg
http://farm2.static.flickr.com/1366/548907933_3b79ea8b80_o.jpg
http://farm2.static.flickr.com/1019/548907957_df509ecd62_o.jpg
http://farm2.static.flickr.com/1262/548907977_bb4d6938ba_o.jpg
http://farm2.static.flickr.com/1322/548907987_1de0748c98_o.jpg
Thanks again!
Cameron
Cameron
waketurbulence
Fri Jun 15, 2007 6:18 am
Do you have the original files at full size? If yes, you can email them to me and I would be more than happy to give you step by step instructions on how I edited them. They are ok shots, but still need proper editing to be acceptable.
-Matt
Longhornmaniac
Fri Jun 15, 2007 7:13 am
Quoting WakeTurbulence (Reply 16):
-Matt
Yes I do, I'll drop you a line on the airliners.net e-mail, and we can exchange email addresses from there. Thank you so much!
Cameron
Cameron
