calfo
My Latest Rejections
Fri Jun 15, 2007 9:32 am
Last time, it got rejected only for having a dust spot. Now, it gets rejected for:
quality
contrast
oversharpened
http://www.airliners.net/uf/536900300/1181866670KWirEc.jpg
Last time, it got rejected for being distant so I cropped it a bit, and now it gets rejected:
quality
dirty
contrast
http://www.airliners.net/uf/536900300/118186691886jzEX.jpg
Last time, it got rejected for being oversharpened, now it get rejected for "soft"
http://www.airliners.net/uf/536900300/1181867095L8NqRu.jpg
If I sharpen it more, it will be oversharpened.
Are any of them re-editable?
linco22
RE: My Latest Rejections
Fri Jun 15, 2007 6:00 pm
Hi Calfo,
Not bad photographs at all.
The first one seems overexposed on the top of the fuselage, something which is always difficult to achieve judging by the light and the fact that its white! Quality actually looks fine to me, but I also think its a bit low in the frame. If you can correct those issue it should be in with a chance.
The second seems blurry to me, just not quite sharp enough, though ita a nice motive. Also a little low in the frame too.
The last shot could just do with that little extra sharpening.
Good luck
Colin
Lanas
Sat Jun 16, 2007 12:54 am
Hi Douglas
First shot is indeed overexposed, as Colin said, but I also see it a bit jagged on the tail (black and red lines), horizontal stabilizers and wingtip flaps. I don´t know where the contrast rejection comes from. Maybe a bit too much contrast? I can´t figure it out. Vertical centering looks fine to me (too much asphalt if not, IMO).
Second shot is a bit blurry and lacks contrast as well. Looks like you´re trying to force the distance issue too much and you lost some quality there. I couldn´t find any dust spots, but with a pass of the equalizing tool you´ll surely see it/them.
Third shot looks pretty OK to me. There are already some jagged areas (registration and left wing), so be careful if you sharpen it more.
Good luck with them. Hope it helps.  bigthumbsup
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
flinhion757
Sat Jun 16, 2007 10:35 am
Quoting Linco22 (Reply 1):
Yah I do agree... the 2nd one is alittle soft. They are gr8 though!
319,320,332,732,733,735,737,738,744,752,763,CR7,CR9,E135,E140,E145,E175,MD82
eadster
Sat Jun 16, 2007 7:35 pm
The first two shots are over-exposed. The KingAir is a great shot indeed. I've done a quick fix, apart from the Dust spot right at the top of the image:
Big version: Width: 1024 Height: 683 File size: 446kb
The 3rd looks like its a tad soft.
calfo
Sun Jun 17, 2007 12:14 am
Thanks a lot Eadster!
The second one is soft because it was shot at 1/80th hand held! I was fooling around with my settings and suddenly, this one came and I didn't have time to change back.
I put the last one in the queue with one more pass of USM.
Users browsing this forum: AlexC and 1 guest
