calfo
Green Hue
Sun Jun 17, 2007 12:19 am
Last time I was in Vancouver, I took some overview shots of the Airport, but the came out with an annoying green hue. I have tried everything I can think about to get them right, but I just can't.
http://www.airliners.net/uf/536900300/1182006980ViJdzQ.jpg
http://www.airliners.net/uf/536900300/1182007029Kb6OBU.jpg
Is there anyone here that would want to ether show me what steps to do to make it look good, or I can also email the original and someone can try and edit it.
Douglas
dbudd
RE: Green Hue
Sun Jun 17, 2007 12:30 am
In CS2 I used auto color which helped a lot then I went into Image>Adjustment>Channel Mixer.
Once there I selected the Output Channel to green and then slid the the green color slider from 100 down to say 96.
Play with it and see what you like...
Dave
[Edited 2007-06-16 17:33:41]
calfo
RE: Green Hue
Sun Jun 17, 2007 12:38 am
Thanks for making me learn a new (for me) tool Dave. I think thats what I needed.
Douglas
calfo
RE: Green Hue
Sun Jun 17, 2007 12:52 am
I think I got the second one right, but I still can't get the first one. Anyone?
calfo
RE: Green Hue
Tue Jun 19, 2007 12:58 am
Anyone know the secret to edit the first one? If anyone knows it, I'd be very happy to email the original and get help.
Lanas
RE: Green Hue
Tue Jun 19, 2007 1:41 am
Douglas
Never use the auto-color function. Try the following: In Photoshop, CTRL+B will open the 'Colour balance' window. There you can play with the channels until you get a decent result. Try working on one or two of the three channels, not changing all of them at the same time.
A couple of comments: the first shot will probably get a motive rejection, because there´s not that much aircraft material in the pic to make such a close-up, and the airport grounds that can be seen are only the tarmac, the grass and a bit of the parking lot. There´s not enough airport action to support a close-up like this and name it under 'Airport overview'.
For the second shot I think you need to apply a bit CW rotation.
Hope it helps.  thumbsup
Cheers  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
