carlos
Crew
Quality Good Enough For A.Net?
Sun Jun 17, 2007 7:28 pm
Hi,
I'm thinking about uploading these two pictures:
http://www.airliners.net/uf/view.fil...8993&filename=1182075827poTo82.jpg
http://www.airliners.net/uf/view.fil...8993&filename=11820756733dGpO8.jpg
Both pictures are taken at Zürich.
Thanks for your advice!
Klaus
eadster
RE: Quality Good Enough For A.Net?
Sun Jun 17, 2007 10:07 pm
The first is fairly grainy in the sky. That will need some attention. Going on past experiences, I'd remove some of the yellow cast also.
The second I like. I'd re-edit, watching the jaggies on the wings plus I'd reduced the brightness a little.
I think the second is the best chance here. I really do like that shot!
GVerbeeck
Sun Jun 17, 2007 11:35 pm
Klaus,
They are both good shots that should easily make it to the database...
Giovanni
carlos
Crew
Mon Jun 18, 2007 3:50 am
Thanks a lot for your advice.
So I will upload them soon.
Greetings Klaus
flyboyseven
Mon Jun 18, 2007 9:16 am
I like in the first one how you can see an Air Canada logo in the paint.
As long as the number of take-offs equals the number of landings...you're doing fine.
