coninpa
Please Help On Quality
Sat Jun 23, 2007 3:23 pm
Hi all,
This one has been rejected for quality and soft
http://www.airliners.net/addphotos/r...741-1500-AB-A320-EC-KDD-EHAM-1.jpg
Softness is most probably recoverable, but can you help me find what are the quality problems ?
Patrick
Patrick De Coninck
eadster
RE: Please Help On Quality
Sat Jun 23, 2007 4:39 pm
Quoting Coninpa (Thread starter):
quality problems
Start smaller. Its way too big. Upload at around 1024 or slightly larger. The Quality will improve a huge amount.
You will need to start with the original and start a new edit. You'll find that with a smaller res, you'll do alot better.
When you sharpen, watch for jaggies that may appear on the horizontal stab.
carlos
Crew
Sat Jun 23, 2007 5:35 pm
Hi Patrick,
I agree with Eadster, it would be better to start with a smaller size. I prefer 1200 x 800.
The picture is soft. Another problem in my opinion is the contrast. The picture also needs a little bit cw-rotation.
Klaus
coninpa
Sun Jun 24, 2007 4:27 pm
Thank you all
I'll try a smaller edit.
Patrick
Patrick De Coninck
paulinbna
Mon Jun 25, 2007 8:32 am
Why so big (original post)all my uploads are at 1024 wide you only lose quality the bigger you get.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
walter2222
Mon Jun 25, 2007 5:45 pm
Quoting Paulinbna (Reply 4):
I would rephrase that to: "if there are quality issues, they are less visible at a smaller size..."
Any conversion to JPEG goes together with a loss, which is a factor of the compression ratio selected.
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
