SNATH
Does Anyone Have The Canon EF 28mm F/1.8 USM Lens?
Wed Jun 27, 2007 7:06 pm
I'm considering getting a Canon EF 28mm f/1.8 USM lens for low-light photography (which includes cabin / cockpit shots, as well as maybe over the wing shots at night). If anyone has it and would like to comment, I'd love to hear from you.
A bit of background: I have a Rebel XTi and I would like a fast prime. The EF 50mm f/1.4 USM is the obvious choice, but on my 1.6x body it would just be too long. I think the 28mm woud be just right and would give me a more useful focal length overall.
I've read all the reviews I could find and the 28mm f/1.8 might be a bit soft wide open, and maybe soft in the corners (the latter apparently is not be a big issue on a 1.6x body). The softness issue is the only one that's preventing me from getting it. Let me know if this is really as bad as some people make it out to be.
Thanks in advance for any comments you might want to share,
Tony
Nikon: we don't want more pixels, we want better pixels.
timdegroot
RE: Does Anyone Have The Canon EF 28mm F/1.8 USM Lens?
Wed Jun 27, 2007 7:30 pm
28mm is too much for cockpits/cabins on a 1.6x crop camera IMO. You really need to get something in the 18mm or lower area.
Tim
Alderman Exit
topgun3
Wed Jun 27, 2007 10:37 pm
Definitely agree with Tim, 28mm is not wide enough for cockpit shots. My lens of choice now is a 16mm Fisheye F2.8 usually with flash.
I have a Sigma 14mm F2.8 (non-fisheye) on order to use for interior shots.
I'd rather be flying.
SNATH
Thu Jun 28, 2007 12:23 am
Quoting TimdeGroot (Reply 1):
Quoting TopGun3 (Reply 2):
Hey guys,
Thanks for the replies. So, I also have a EF 17-40mm f/4 that I'm planning to use in most cases. I just wanted an alternative, when the light is really bad. The 14mm L would be nice, but it's just too damn expensive!!!
Tony
DM
Thu Jun 28, 2007 12:36 am
Quoting SNATH (Reply 3):
Then why not go for the 15 f/2.8? Its only a little more than the 28 f/1.8 and not nearly as much as the 14 L.
SNATH
Thu Jun 28, 2007 2:00 am
Quoting DM (Reply 4):
The fisheye? Yeah, I considered it. I wanted something faster and with USM.
Tony
Buyantukhaa
Fri Jun 29, 2007 12:56 am
Quoting SNATH (Thread starter):
At f/2.2 it's sharp as a knife. You do get some purple fringing at f/1.8 though, that's correct. I use a EOS400D as well.
I scratch my head, therefore I am.
GVerbeeck
Fri Jun 29, 2007 1:44 am
It seems to be a nice lens on paper but apparently it suffers from bad corner quality.
Check out this extensive test: http://www.photozone.de/8Reviews/lenses/canon_28_18/index.htm - and yes, that's on a crop cam...
aviopic
Fri Jun 29, 2007 2:48 am
Quoting SNATH (Reply 5):
I think both criteria are not so important for cockpit shots, I've a 15mm/2.8 fisheye but never used it wider then +/- F7.1 inside an A/C as you do need some DOF.
USM is a "nice to have" at best on a short lens with little travel but certainly not a requirement.
The truth lives in one’s mind, it doesn’t really exist
DM
Fri Jun 29, 2007 2:52 am
Quoting Aviopic (Reply 8):
True, if you were to take cockpit shots during day time you could still shoot around f/7.1-8 range and have nice results and if shooting at night the f/2.8 can still give you ok results but you can easily carry a small tripod around.
