aero145
Has My Sharpening Gone Seriously Mad?
Thu Jul 26, 2007 11:33 am
Hello fellas.
I just checked my queue to see 6 photos gone and no accepted, saw 6 photos rejected for oversharpened, shots that looked fine on my screen, and bit oversharpened on my mother's screen.
http://www.airliners.net/addphotos/rejections/big/20070726_TC-ACZ-1465-17062007-CLN-DAe.jpg
http://www.airliners.net/addphotos/rejections/big/20070726_N439SR-8261-14072007-HL-DA.jpg
http://www.airliners.net/addphotos/rejections/big/20070726_TF-JMB-8132-14072007-DAE-HL.jpg
also quality, but I thought that Dash 8s were not common on grass airfields (and shots taken a couple of meters away on takeoff weren't ether common)
http://www.airliners.net/addphotos/rejections/big/20070726_274-1493-17062007-CLN-DAE.jpg
http://www.airliners.net/addphotos/rejections/big/20070726_TF-KAH-8255-14072007-HL-DAE-1DIIn.jpg
http://www.airliners.net/addphotos/rejections/big/20070726_TF-NPK-TF-JMB-8079-14072007-HL-DAE.jpg
What is wrong here? My screen too soft? The screener's screen too sharp? My acceptance ratio has now gone all the way to 60% and I'm getting worried.
Many thanks,
David
p.s. A 'teacher' of mine recommended me to sharpen using USM, 200% 0.2, applied two times. I need, on my screen, to do it four times or sometimes even more, to get satisifiing sharpness. I guess I'd stick to two-times... yes?
RCoulter
RE: Has My Sharpening Gone Seriously Mad?
Thu Jul 26, 2007 11:50 am
On my screen, they look WAY over sharpened.
Fly747
Thu Jul 26, 2007 11:52 am
LEGO all the way.
Ivan
bubbles
Crew
Thu Jul 26, 2007 11:55 am
Quoting Aero145 (Thread starter):
also quality
Because it also looks grainy.
_Hongyin_
Granite
Thu Jul 26, 2007 4:11 pm
David
The DC3 and Dash 8 image is really nice.........very nice actually............but the processing is not your usual standard.
Definately oversharpened.
Gary
aero145
Thu Jul 26, 2007 10:06 pm
Quoting Bubbles (Reply 3):
read what I said: "but I thought that Dash 8s were not common on grass airfields (and shots taken a couple of meters away on takeoff weren't ether common)"
Quoting Granite (Reply 4):
Too much sharpening eh? I don't know what my "usual standard" is! Should I rework them with less sharpening and upload again? Should I try using a sharp Apple screen for right sharpening?
David
PS: http://www.airliners.net/addphotos/r...Regional-4523-11062007-BSL-DAE.jpg
Rejected for overexposed, it seems that the only reason is that there's a little patch on the nose that's "too hot" (screener said). What's going on?! Am I getting crazy or are the standards going up like a rocket?
edit: and oh, I bought Spyder calibration system, learned how to calibrate, and more problems...
[Edited 2007-07-26 15:09:00]
acontador
Thu Jul 26, 2007 11:01 pm
Hi David,
All pictures as shown have serious problems (and I mean serious  Wink ), mostly way oversharpened, and some have also problems with brightness/contrast. Having seen many of your other pics I think as Gary pointed out this is purely an editing problem. You just need to get a grip on your monitor settings again, and I'm sure it will be fine!
 checkmark
Just sit back, relax and have a glass of Merlot...enjoy your life!
bubbles
Crew
Thu Jul 26, 2007 11:06 pm
Quoting Aero145 (Reply 5):
read what I said
I just wanted to tell you that shot was not only oversharpened, but also a little grainy. That's why 'quality' was given.
aero145
Thu Jul 26, 2007 11:08 pm
Quoting Acontador (Reply 6):
Thank heaven (sorry for saying this as I don't believe in God)! But I must, as you said, get a grip at the monitor settings... but still I don't get this... sharpening fine on THIS screen, means that THIS screen is not in order... I didn't know you could change the sharpness of screens, or what?
 checkmark
Gracias!
aero145
Thu Jul 26, 2007 11:09 pm
Quoting Bubbles (Reply 7):
yeah alright  Wink
ilikeflight
Thu Jul 26, 2007 11:13 pm
As already said they are Way oversharpened
Think Different
aero145
Thu Jul 26, 2007 11:19 pm
Quoting Ilikeflight (Reply 10):
Oh, you surprise me!  sarcastic
LHRsunriser
Fri Jul 27, 2007 12:24 am
Yh they are oversharpened. Almost to a stage where extreme heat causes jaggies. Maybe just undersharpen them on your screen to adapt.
Cheers Dom
Getting back into it
DM
Fri Jul 27, 2007 1:14 am
Quoting LHRsunriser (Reply 12):
As in sharpen less?? You can also sharpen on your moms screen and then send it to your computer to get an idea what it should look like on your computer.
DM
INNflight
Fri Jul 27, 2007 1:32 am
Quoting Aero145 (Reply 8):
Of course you can!
If you want them in, probably  Wink
F.
Jet Visuals
aero145
Fri Jul 27, 2007 3:36 am
Quoting DM (Reply 13):
Guess I'll take a look at this...
Quoting INNflight (Reply 14):
Of course you can!
Then teach me, Lord Florian.  Wink
So you thought I upload only to get more rejections?  Wow!
INNflight
Fri Jul 27, 2007 5:39 am
Quoting Aero145 (Reply 15):
Well nothing to teach here, at least at my screens you can  Wink
Jet Visuals
whappeh
Fri Jul 27, 2007 5:51 am
Resubmit that DC-3/Dash-8 Photo. I very much like it. (After re-editing, naturally)
-Travel now, journey infinitely.
aero145
Fri Jul 27, 2007 6:07 am
Quoting INNflight (Reply 16):
Heh heh heh!
Quoting Whappeh (Reply 17):
Will re-edit all the photos that were rejected [except the takeoff Dash 8, Hongyin  sarcastic ], upload them on the net and post here. Will use my screen and not sharpen more than 200% 0.2 x 2 and 75% x 1.
Cheerio,
David
dvincent
Fri Jul 27, 2007 6:40 am
I'm curious then - why wasn't the grainy reject used instead of quality?
IMO, Quality is kind of an unnecessary item. If the photo is rejected, then it stands to reason that it didn't have the quality necessary to be accepted. If there's JPEG artifacts, then there should be a compression artifacts rejection. "Quality" is far too vague and can mean too many different things.
From the Mind of Minolta
currymonster
Sat Jul 28, 2007 4:09 am
Hi,
A big hello to you all  Smile I have been reading this forum for a while now and would like to thankyou all for the excellent advise given over the last year, I am now able to post at last!!
I am a new paid up member now I can post  Smile like everyone else yes they appear oversharpened, but when you double click them and open up in a full browser window they loose the jaggies.
This is a phenomenon that has always baffled me, as this has also happened to some of my shots, and I often think....yes they show jaggies but open them up into a large window please and they go!!
Could anyone please advise me on this, I hope I haven't "hijacked" this thread, I guess it follows on from what we are all talking about.
Thanks in advance
Steve
DM
Sat Jul 28, 2007 7:09 am
Welcome Steve!
Quoting Currymonster (Reply 20):
I am a new paid up member now I can post like everyone else yes they appear oversharpened, but when you double click them and open up in a full browser window they loose the jaggies.
Um... not to be rude but everyone knows that...
DM
IngemarE
Sat Jul 28, 2007 4:00 pm
Aero145,
.....care to let us know what new screen you are using?!
I quite recently bought myself a new screen as well, and it has a whole range of different sharpness pre-settings.
Most of which make the pic's look really awkward, if you ask me!!  Yeah sure
I have a few pic's in the queu that have been edited on the new screen and I'm interested in seeing how they make it through the screeningprocess.
In thrust I trust.
aero145
Sat Jul 28, 2007 7:48 pm
Quoting IngemarE (Reply 22):
I use an old TFT screen that I don't know the name of, my mom's screen is a PowerBook screen - a very "high acceptance" photographer here in the DB uses a PowerBook screen for all his photos and they are superb.
So, I will maybe be using an iMac screen but not yet.
So, I'm not using a new screen.  Smile
currymonster
Sat Jul 28, 2007 8:57 pm
DM
Quoting Aero145 (Reply 23):
Not for me to be rude DM but, did you read the rest of my message as follows
It was a request for help based on the post I replied to, I didn't find your statement too helpful.
Steve
brianw999
Sat Jul 28, 2007 9:14 pm
Quoting Aero145 (Reply 18):
Might I suggest using unsharp mask settings of 50__0.2__0 and take the sharpening up gradually until you first see some jaggies. Go back one step with Ctrl+Z and then use a layer mask between each sharpening pass, erasing any jaggies etc. that appear, as you go ?
Granite
Sat Jul 28, 2007 9:29 pm
Steve
Quoting BrianW999 (Reply 25):
Don't worry about that......David does it all the time  eyebrow
Gary
brianw999
Sat Jul 28, 2007 11:59 pm
Quoting Granite (Reply 26):
Steve
Gary
Huh ?
Where did I say that ?
[edit] Ah, I see it was actually currymonster that said it. Errant cut and pasting Gary ?  Big grin
[Edited 2007-07-28 17:02:53]
aero145
Sun Jul 29, 2007 3:17 am
 box   Yeah sure
Granite
Sun Jul 29, 2007 4:28 am
Hi Brian
Something went wrong as I clearly used the quote from Steve's post but for sme reason it pulled in your name.
Ooops, sorry David......hijacking your thread
Gary
Edit......just noticed on another post the same ting happened. omething wrong with the 'Quote' feature. Maybe best to check before sending.
[Edited 2007-07-28 21:31:57]
Granite
Sun Jul 29, 2007 4:33 am
..and my spelling by the looks of it  Smile
Sorry David...again!
Gary
ptrjong
Sun Jul 29, 2007 4:39 am
Quoting Granite (Reply 29):
Happens all the time... you select text from one post, press the Quote button in the next post, and voila...
Perhaps the new management can disable this Wink
Peter
Fly747
Sun Jul 29, 2007 5:16 am
You should always view the large version of the picture because that is their true size. Any downsizing will result in jaggies and possibly other issues.
Ivan
currymonster
Sun Jul 29, 2007 6:34 am
Thanks Fly,
So when we reduce the size to around 1200, is the photo viewed by the screeners at this size or do they zoom in to check it
Sorry for the ignorance
Steve
DM
Sun Jul 29, 2007 7:03 am
Quoting Currymonster (Reply 33):
Say a photo is uploaded at 1024 pixels wide, the screeners will see it at 1024 pixels wide. There wont be any need for them to zoom in because it will open up in the size you sent it to them. Same follows for 1000 thru 1600 pixs.
Basically, they see it in actual pixels.
DM
aero145
Sun Jul 29, 2007 10:07 am
Quoting Currymonster (Reply 24):
But you just did.  sarcastic
Quoting Granite (Reply 30):
Jajaja, right...
Guess I'm going to let you guys use this thread and make a new thread...  crazy
INNflight
Sun Jul 29, 2007 2:50 pm
Quoting Aero145 (Reply 35):
Come on David, it's all been said anyway  Smile
Florian
Jet Visuals
