captalves
The Right Stuff..
Mon Aug 06, 2007 11:20 pm
I am an airline captain flying the Airbus A332/343/345, and also interested in aviation photography. Would like to hear opinions in which would be a good lens to use for taking pictures of planes from inside the cockpit whilst flying, and also from the ground of a planes flying. I have used the 18-200VR but feel that i need something with a little more reach and quality.
My equipment as follows:
Nikon D200
18-200VR f/3.5~4.5G
What i have looked at and like but in no particular order is:
Nikon 70-200VR AF-S f/2.8
Nikon 300 f/4D IF-ED
Nikon 300 f/2.8G IF-ED VR
Nikon 200-400 f/4G IF-ED VR
Sigma 100-300 f/4 EX DG HSM
Sigma 120-300 f/2.8 EX DG HSM
Sigma 300 f/2.8 EX DG HSM
I know these lenses vary in prices and quality, so im happy to hear pros and cons.
Final question, Fixed or Zoom lens? whats the view on this? (pun not intended) pros and cons again.
Thanks in advance,
Antonio
psyops
RE: The Right Stuff..
Tue Aug 07, 2007 1:01 am
Welcome to the photography forum!
I don't think thee is any simple answer to your question - there are many options and personal preferences to take into account. You have listed some pretty fine glass as options you have already looked into.
I can give you my preferences, based on the set up I use with my Nikon equipment.
When I am either near home (and travelling in my own vehicle) or travelling for photography specific purposes I take the following lenses (all Nikkor):
10.5 f/2.8
17-55 f/2.8
70-200 f/2.8
200-400 f/4
The 10.5 would be great for cockpit shots, the 17-55 may work as well (never done cockpit shots), but could be tight considering on a D200 it is equivalent to a 27.2 mm lens at the short end.
The 17-55 is a big honking piece of glass considering the focal length range it has, so size and weight can be a consideration - you really have to try one mounted to a camera to appreciate it. It can (combined with a good operator) make some great images.
17-55:
Photo © Peter Nickerson
The 70-200 is one of the best pieces of Nikon glass around. IMO this would be the first thing I would get. Mine is welded onto one of my D2Xs bodies. The 80-200 is no slouch either.
80-200:
70-200:
The 200-400 - this is serious glass and serious large. I have the 300 2.8 and like to use it for sports as the wider aperture allows for better OOF backgrounds in sports plus more light (aperture) for indoor sports. The 200-400 is very versatile though, and I use it for football, soccer and of course aviation. It does take some getting used to handling due to the size, a monopod is required for anything more than 2 or 3 frames. The 300 f/4 for aviation is great piece of glass, not too large and in aviation you don't need the wider end of the aperture.
200-400 examples:
When I travel on short hops where the aviation photography is a secondary attraction, I take my 80-400VR. Not as fast and perhaps not as sharp out at 400 but quite a few of my images on here are with this lens.
Hopes this helps. In the end, you can't really go wrong quality wise with what you have listed.
[Edited 2007-08-06 18:13:44]
CalgaryBill
Tue Aug 07, 2007 1:09 am
Well, the 70-200 VR is one of Nikon's classics, but it won't give you any more reach than your 18-200. It will, however, work with teleconverters (stick with 1.4x or 1.7x to start) which I don't believe will work on the 18-200. If 200mm is enough range for you then this is an excellent lens.
The Nikkor 300/2.8 and 200-400/4 are fantastic lenses (although neither will work well in a cockpit!). If you're in that market the big question for you is speed vs flexibility: the 300/2.8's wider aperature will allow faster shooting, but if you mainly shoot in daylight that's probably not an issue. The 200-400/4's zooming versatility is very useful for events like airshows where you're shooting all different sizes of planes at a wide variety of distances. I went with the 200-400 for that reason. Both will work reasonably well with teleconverters...
For your in-cockpit shots, you might want to consider the 70-300 VR that Nikon released last year. It's more in the consumer range (price wise and construction materials) but it does produce excellent images. It's much smaller than the other Nikon lenses you mentioned and it's much lighter, so it would be easy to wield in a cockpit and wouldn't add much weight to the flightbag.
http://nikonimaging.com/global/produ..._zoom70-300mmf_45-56g_if/index.htm
B
captalves
Tue Aug 07, 2007 1:26 am
Thanks for the replies.
I have to admit i have always like the 70-200VRf/2.8 since i got started in SLR photography and i keep coming back to it. I agree with the size issue in the cockpit even though the Airbus isnt that small but i guess something more compact would be easier like the 70-300VR you mentioned.
Any tips for taking air-to-air pics from the cockpit with re to shutter speeds etc. trying to find the best to capture a plane coming the opposite way with a closing speed of 1800kmph and 1000ft vertical seperation.
thks
CalgaryBill
Tue Aug 07, 2007 3:42 am
Quoting Psyops (Reply 1):
I find the 17-55 tight, but a good compromise between great image (the 17-55) and fisheye distortion (the 10.5) is the 12-24mm Nikkor. Some folks also seem to like the 10-20 from Sigma (or is it Tokina?) but I haven't used the third party ones so can't comment.
Quoting Captalves (Reply 3):
Can't help you there, haven't done anything that fast. But for autofocus, you'll probably get the fastest response using AF-C (continuous) and set the Lock-On time to "normal," "short" or "off." Apparently the autofocus lags if you set it longer, but I've only used "normal" or shorter, so I don't know how significant the lag is on longer settings...
B
aviopic
Tue Aug 07, 2007 8:06 am
Quoting CalgaryBill (Reply 4):
Tried the Sigma 10-20 last weekend for the very first time.
On my 20D it gives a wider angle then the 15mm fisheye, it's quite sharp and little to no distortion.
Big version: Width: 800 Height: 591 File size: 427kb
A side note: I took this image with the camera up side down to get the flash where it should be......... at the bottom  Wink
The truth lives in one’s mind, it doesn’t really exist
777MechSys
Tue Aug 07, 2007 8:20 am
I thought you switched to cannon.  Wink BTW If you still shoot Nikon you need to get a new pass code to get into the KPAE Nikon Spotters Club. (Talk to Royal)
10.5 is awesome for cockpit shots.
Photo © Erick Lopez
Photo © Erick Lopez
psyops
Tue Aug 07, 2007 8:39 am
Quoting 777MechSys (Reply 6):
Did you guys oust me due to the impure Canon thoughts already so I have to re-apply?
Never fear, still have the "deuces". I am thnking of a late September/early October trip to KPAE.
You picked up a 10.5 obviously - looks great!
777MechSys
Tue Aug 07, 2007 11:39 am
Quoting Psyops (Reply 7):
We always enjoy having you in town. My trip to Whitehorse is falling apart.
I completely blame you for the 10.5mm. I never should have borrowed yours that day.
FighterPilot
Tue Aug 07, 2007 12:08 pm
Quoting Captalves (Thread starter):
Nikon
Well theres your first problem.  Wink
Welcome to the photography forum.
Cal  airplane
*Insert Sound Of GE90 Spooling Up Here*
DM
Wed Aug 08, 2007 1:49 am
Quoting FighterPilot (Reply 9):
Darn... Its supposed to be Canon isnt it??  Yeah sure
777MechSys
Wed Aug 08, 2007 6:54 am
Quoting DM (Reply 10):
Stellar observation!  expressionless  Nothing make it past you.
Users browsing this forum: FAST Enterprise [Crawler] and 9 guests
