acontador
Some Twilight Pictures - Worth A Try?
Fri Aug 10, 2007 3:40 am
Actually most probably not!  Wink
I was experimenting a little at the airport under some twilight/overcast sky late evening, and these pics are (the best) result. Most probably they will never make it to A.net, but nevertheless I wanted to share them with you - who knows, maybe one of you has a good idea how to fix them!
- Aerolineas Argentinas 737 landing. This one is almost a silhouette, shot Av f/4.0 1/50 sec @ 200 mm
- Chilean Air Force only tanker 707 (looks blurry), shot Av f/4.0 1/40 sec @ 84 mm
- Aerolineas del Sur 737 (looks too dark), shot Av f/4.0 1/125 sec @ 122 mm
- Cielos del Peru DC-10 (also too dark), shot Av f/4.0 1/60 sec @ 73 mm
Any comments appreciated!  Smile
Just sit back, relax and have a glass of Merlot...enjoy your life!
JeffM
RE: Some Twilight Pictures - Worth A Try?
Fri Aug 10, 2007 5:33 am
Quoting Acontador (Thread starter):
I'd go with all, not most.
Shoot them earlier in the evening.
acontador
Fri Aug 10, 2007 6:50 am
Hi Jeff,
Thanks for taking your time to answer!
Quoting JeffM (Reply 1):
That would be too easy, wouldn't it!
Lanas
Fri Aug 10, 2007 8:22 am
Andrés
707 and AR shots are blurry. The Cielos and Aerolineas del Sur are better, I´d give them a try, maybe. Cielos one is jagged in places, beware of that. Have you used any noise reduction program?
Good luck with them.  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Users browsing this forum: Borut, JakTrax and 1 guest
