AirMalta
Aircraft Carrier Photos
Thu Aug 16, 2007 6:44 am
Can some one tell me pls If you take a photo of an aircraft carrier with aircrafts on the deck but the picture shows the whole carrier in it and not close ups of the aircrafts on deck!Will this be rejected?
Thks
Malcolm
JeffM
RE: Aircraft Carrier Photos
Thu Aug 16, 2007 6:55 am
Depends on the image, and how you classify it. This ain't Aircraft Carrriers . net  Wink
AirMalta
Thu Aug 16, 2007 6:58 am
Quoting JeffM (Reply 1):
Its a good idea that this will be added to the site !!what do you think?
malc
GimliGlider
Thu Aug 16, 2007 7:21 am
Can we see the photo?
"You could attach that to your house and still go 0-60 in 5 seconds..."
AirMalta
Thu Aug 16, 2007 7:42 am
Actually I dont have it available yet but I intended going to take some from the air when she sails out from the Grand Harbour.
Malc
walter2222
Thu Aug 16, 2007 8:02 am
Hi Malcolm,
I wish you good hunting!
Something like this, maybe?
Photo © Kamil Macniak - Epgd Spotters
Good luck,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
AirMalta
Thu Aug 16, 2007 6:31 pm
hi walter how r u?yes something similar
malc
Kukkudrill
Thu Aug 16, 2007 7:01 pm
Hi Malc
This seems to be a very subjective area. I had a photo of the Principe de Asturias, taken from the Upper Barracca, accepted, but a similar photo of the Illustrious when it had visited back in 2005 was not accepted. In the meantime Jetphotos accepted the Illustrious shot but not my Principe de Asturias photo. Go figure. Still, you should definitely try your luck. After all aircraft carriers are floating air bases, and airport overviews do get accepted on a.net -- even though it ain't airports.net!
Charles
Make the most of the available light ... a lesson of photography that applies to life
ptrjong
Thu Aug 16, 2007 9:56 pm
Quoting Kukkudrill (Reply 7):
Hi Charles,
Although carrier shots are not in the Airport Overview category apparently? Just to save Malcolm a category rejection.
Peter Smile
AirMalta
Thu Aug 16, 2007 11:23 pm
http://www.airliners.net/open.file/0632266/M/
hello Peter similar like this shot look at it...superb
Malcolm
Kukkudrill
Fri Aug 17, 2007 4:56 am
Quoting Ptrjong (Reply 8):
Hello Peter
You are right. I wasn't referring to the categories to be ticked: all I meant to say is that if airport views are accepted, logically the same should apply to aircraft carriers. But it's good to clarify.
Charles
