lufthansi
Is This Helicopter Pic A.net Worthy?
Tue Aug 28, 2007 1:37 am
Hi!
Yesterday I made this picture slightly against the sun. The backdrop is totally white therefoe but for some reason the chopper turned out ok.
Any comments so far? The backdrop is boring I know. It's actually not there. Makes it the pic unique? Maybe a stupid thought. Anyhow. Your thoughts are welcome.
Stephan
http://i27.photobucket.com/albums/c184/lufthansi/IMG_8401.jpg
Life starts at take-off!
EK20
RE: Is This Helicopter Pic A.net Worthy?
Tue Aug 28, 2007 1:40 am
Stephan,
The sky isn't white - it looks pink and the aircraft is too far in the distance.
lufthansi
Tue Aug 28, 2007 1:56 am
Pink!? Hum. Love is in the air. Ok. I'll try an edit. A bit more contrast should turn pink into white.
http://i27.photobucket.com/albums/c184/lufthansi/IMG_8401Edit.jpg
bubbles
Crew
Tue Aug 28, 2007 1:57 am
Hi Stephan
The helicopter is in the distance. You have to crop it tighter. And some sharpening is needed. Because this photo is a bit backlit, it will be hard to get contrast right (now the helicopter looks dark). If simply bumping up the brightness, you could find the sky will be overexposed.
Oh, yes, the sky's colour is slightly off. It looks a little pink to me.
_Hongyin_
bubbles
Crew
Tue Aug 28, 2007 2:00 am
Hi again
Your second version looks unbalanced. The soft and contrast problems are still.
_Hongyin_
ThierryD
Crew
Tue Aug 28, 2007 2:05 am
Quoting Lufthansi (Thread starter):
Stephan, as you already noted yourself the photo was taken against the sun and that killed it. The background is so bright it hurts when looking at it.
The chopper while ok is still soft/blurry.
While the picture is not for here it might perfectly well serve other purposes (e.g. ads) where the lack of background is required.
Thierry
"Go ahead...make my day"
